Where to inject smoke oil on headered saito
AB, CANADA
I'm installing a smoke system on my P6-E Hawk and was wandering what your thoughts would be on an injection location. I plan on wrapping the header close to the motor with 1/8th brass tubing for preheating. The header is about 5" long and was wondering if the temps might not be high enough at the muffler because of the length and if I inject on the collar of the header at the motor if there would be a problem with back pressure?
flynte
flynte
AB, CANADA
RE: Where to inject smoke oil on headered saito
Thanks for the reply, Minn. I was also totally thinking this way also for great heat!That corigated header will totaly vapour the oil, but, you think that I may hit a pressure issue at the pipe?
flynte
flynte
AB, CANADA
THANKS so much. I have been losing sleep lately trying to work this out. Dreaming of great loops, spins and hammer heads with smoke but end up waking up to the how can we get er done!
flynte
flynte
