Reload this Page >
Problem Binding DX7 to AR6200
Old 10-25-2010, 09:43 PM
mcandies
Default Problem Binding DX7 to AR6200
I went through the binding procedure, bind plug attached, power on, blinking lights, press bind button and turn on receiver. Both receiver lights went to solid. Removed bind plug and light on main receiver went very dim and could not see light on satellite receiver. No servos move. I have 2 brand new AR6200 receivers and they both do the same thing. Any suggestions?
Old 10-25-2010, 11:42 PM
huck1199
huck1199's Avatar
Default RE: Problem Binding DX7 to AR6200
Power down RX before removing bind plug.
Old 10-26-2010, 01:50 PM
BarracudaHockey
BarracudaHockey's Avatar
Power down both the receiver and transmitter, and power the whole system back up.
What power source are you using?
FLAPHappy
My Feedback: (209)
Follow the instructions in the owners manual. Be on the model you want to bind, like model 3 or 4, etc then turn off the transmitter.
Use your on off switch and connect battery to any vacant channel on the RX
Put the Bing plug in, where the Batt. usually go's.
Turn on the switch, you should see blinking lights, 1 on the main RX, and 1 on the Satellite RX.
On the Transmitter,Hold the Bind button on the Transmitter, down, then turn the transmitter.
In s few seconds the blinking lights on the RX's will go solid.
Turn off the switch,turn off the transmitter.
Unplug the Bind plug, and connect the battery to the RX, where it normally go's.
After you have done that, turn on the transmitter, then turn on the Receiver, it will lock up and you are done.
Remember, once you have changed any programming for that model, such as servo reversing, etc, RE-BIND the receiver again!!!. That is your Failsafe.
Hope that helps.
Old 10-26-2010, 01:51 PM
BarracudaHockey
Power down both the reciever and transmitter and remove the bind plug. Then power up the tx, wait a few seconds, then power up the reciever.
What are you using to power the receiver?
