cutting pink foam for wings
Reply
Old 11-01-2010, 01:36 PM
Racewizard
Racewizard's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default cutting pink foam for wings
Having a problem cutting pink foam for wing cores, every time I cut wings it wants to warp from end to end. Has anyone had this problem and if you have how did you solve it
Racewizard is offline
Old 11-01-2010, 01:45 PM
da Rock
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: cutting pink foam for wings
Look at the resulting surface.
If it shows "smearing" the heat caused localized shrinking. Try a different heat setting and pull speed.
Heck, no matter what the surface looks like, try different heat and speed.
da Rock is offline
Old 11-01-2010, 04:45 PM
huck1199
huck1199's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sounds like the center of your wire is hotter than the ends, which is normal but the center is too hot causing shrinkage like Da Rock said. Cut down the voltage.
huck1199 is offline
Old 11-02-2010, 08:32 AM
MinnFlyer
MinnFlyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The good news is... It shouldn't matter.
Once you add sheeting and hold the whole thing flat, the sheeting should hold any warp out.
MinnFlyer is offline
Old 11-02-2010, 06:57 PM
Racewizard
Racewizard's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks guys, I'll try the temp setting and see what happens. I know it really doesn't matter but it still shouldn't do it, and it would be nice to have a straight wing to begin with
Old 11-09-2010, 08:43 AM
rtstestpilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It sounds like your heat setting is too hot. I don't know if you have some type of machine to pull the cores or are hand pulling them. Ideally, the heat setting should be just hot enough to melt the foam. I set mine by putting the bow on the foam and then dialing up the heat till it just starts to melt into the foam. The next thing of importance is the pull pressure and rate of cut. Just enough force should be given to start the cut without bending the wire; let the wire do the work. With a set of glass smooth templates and whats talked about above, you should have glass smooth dead flat cores. Good luck, Todd
rtstestpilot is offline
Old 11-09-2010, 10:04 AM
Desertlakesflying
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Get in touch with cpt nj on here, do a search. He's cut a few wings with pink foam, and he's really good at it
Desertlakesflying is offline
Reply
Display Modes
