Running Servo Wires through wing??
IA
Hello,
I was just wondering what you guys use to run your servo wire through the wing to the center to hook up into the fuselage.
RE: Running Servo Wires through wing??
Fishing weight on a string and let gravity help take it through the ribs. Then fish the wire through with the string. Or if I'm building a kit, then I add paper tubes through the ribs, so I can just push the wire through the smooth tube.
NC
I tie an end of a string to a clunk and tie the other end to the servo lead. Hold the wing up and drop the clunk in so it drops down through the opening in the ribs until it reaches the opening at the wing root. Fish the clunk/string out with a piece of bent push rod, then pull the string until the servo lead comes out.
When framing a model I use model rocket body tubes. I keep a few packages of tubes layin around in various sizes. They cost 50 to 75 cents for an 18" tube. They are very strong when glued into a wing.
NC
For years I have either used clear, or this time colored, book report covers you can get for school supplys. They are light weight, & cut & shape easily. Drop a sting with a small weight on it & pull the wires through. Bill
For the last 4-5 years of assembling ARFs, I haven't used anything. It's been fairly easy to hold the wing vertical and let the wire work it's way through. It takes some wiggling but hasn't ever taken more than a minute or two. Once you get the hang of it, it's fairly easy. Some of the better ARFs have string in place to pull the plug through. In this case, you get more than you pay for.
My Feedback: (14)
IN
Buy some of the beaded chain that is used on pull/pull ceiling lights. It's the little brass ball stuff. You can get it at any hardware store. Stand the wing on end, insert the chain and shake a little. The chain will find it's way through the wing rib holes . Tie the servo lead on and pull it back through. This chain makes the job very easy.
ORIGINAL: Steve Percifield
ORIGINAL: bullseye000
I didn't think anyone else did this. If I build I put the string in before covering but this is really the way to go for an ARF. I have a long piece that I salvaged out of some old vertical blinds we pulled down during a renovation.
