On Board glow driver
My Feedback: (10)
Hi
Bought this plane from a flyer's widow. She had no idea what kind or make it was, nor any information on its workings. I've flown for years but never had a on-board glow driver before and don't have a clue as to how it works or the switches involved. I tried to lable what I have as best I can. Would appreciate and help I can get. Also.... maybe someone can identify the plane too. Thanks
Dick
Dick
RE: On Board glow driver
Its been a few years since i used an onboard glow driver, but it looks like the servo is working the micro switch, turning on/off the glow driver. There must be an onboard battery seperate from the reciever battery that fits into the picture somewhere. Most of the newer Glow drivers are turned on/off via the throttle stick. Im thinking this was maybe something home grown? Im sure others will chime in and have other ideas.....Gene
Unless there is something going on that is not appearent in the pics.....I don't think you'd need the on board glow for a up right mounted engine.....make sure that you have the proper length, and heat glow plug and see if you can get a good idle......
You'll save the weight of the glow driver
