HINGE GLUE
My Feedback: (15)
NJ
HINGE GLUE
Can someone tell me what is "hinge glue"? I'm building a model that has flaps and since the CA hinges are only accessible to one side, the instructions are saying to use "hinge glue" and NOT thin CA glue. I have never heard of 'hinge glue'. Can someone tell me if there is a substitute that I can use? Thanks.
RE: HINGE GLUE
There IS a type of glue called "Hinge Glue", but if you're using pinned hinges or Hinge Points for the flaps, you can use pretty much anything from wood glue to epoxy. My choice would be 30-min epoxy.
I also usually put a small dab of vaseline on the pivot and heat it up with a lighter so it melts into the pivot - this prevents glue from getting in there.
My Feedback: (29)
RE: HINGE GLUE
ORIGINAL: newflier1
Pacer makes an adhesive called " hinge glue " it remains somewhat flexable when dry. It sounds like the manufacturer is using CA hinges to save cost but discovered that they can't be installed with thin CA because of of access issuesand mayhave found that the use of epoxy or any glue that dries hard may create an issue with the hinge at the flex point. I would replace the CA hinge with a good quality flat pinned hinge installed with either epoxy or poly glue.
RE: HINGE GLUE
ORIGINAL: speedracerntrixie
It sounds like the manufacturer is using CA hinges to save cost but discovered that they can't be installed with thin CA because of of access issues and may have found that the use of epoxy or any glue that dries hard may create an issue with the hinge at the flex point. I would replace the CA hinge with a good quality flat pinned hinge installed with either epoxy or poly glue.
My Feedback: (29)
RE: HINGE GLUE
This leads me to beleive that the manufacturer included CA hinges to be used with the flaps.
My Feedback: (15)
NJ
RE: HINGE GLUE
Yes - the ARF has CAhinges "pre-installed" in the flaps. The instructions just say NOTto use thin CA glue since you can only get to them from one side. They say to use 'hinge glue". I've never heard of hinge glue.
RE: HINGE GLUE
newflier1,
You don't mention what airplane.
There are hinges called "pin hinges" and a number of other hinges that are made of hard, flexible plastic. Those used to be glued in with epoxy. If the instructions for your airplane have included hard hinges, they're glued in nowadays with epoxy or hinge glue, a product that used to be sold under the Pacer brand name. It came in a very small somewhat flat bottle.
OK, your last post helps some.
My Feedback: (15)
NJ
RE: HINGE GLUE
The plane is a Hangar 9 Spitfire. They are CA hinges (100% sure of this). The issue is that when you install the flaps you DONOT have access to BOTH sides. When you use CA hinges, you are suppose to apply thin CA glue to BOTH sides of the hinge. The instructions state this fact and say to use 'hinge glue' instead of thin CA glue. Hope that clarifies things a bit.
RE: HINGE GLUE
If you can only glue one side at a time, there are a couple of glues that will work with CA type hinges.
The Pacer hinge glue is one. Epoxy is another.
I would guess they flap installation has you apply glue to hinge the wing or the flap, place the hinges into whichever you chose, then apply glue and slide the hinges into whichever part doesn't have hinges inserted yet.
30minute epoxy would work for that. So would the hinge glue. One of my 2 LHSs still sells the stuff.
My Feedback: (15)
NJ
RE: HINGE GLUE
Thanks. I think I am just going to use 30 minute epoxy and use some light grease or vasiline to protect the flap from getting glued to the trailing edge of the wing where it rests aginst. I might just check everything for alignment first, glue the CA hinges into the flaps (let dry) then glue the flaps with the hinges into the wing. That should work.
RE: HINGE GLUE
OK, now we got something to go on..........
I built my H9 Spitfire without referring to the manual for much. Been doing this for over 50 years and usually do things in the easiest sequency, which often isn't the way some mfg's suggest.
You actually have perfectly adequate access to both sides. CA works well, and is easy to apply.
RE: HINGE GLUE
ORIGINAL: newflier1
A couple of suggestions.
The use of epoxy with fuzzy CA hinges really has some drawbacks. To apply CA safely to those hinges was dead simple for me. I saw the very slight risk, and simply had some pieces of paper towel handy. Get the flap positioned with the hinges in place, and simply open the flaps. Apply the CA to the inside of all hinges and turn the wing over. Close the flaps to about 1/4 open and apply the CA to the outside.
Those hinges are going to suck in the CA just like aileron, rudder, and elevator hinges do. If you get any CA anywhere else, just like happens gluing ailerons, rudders, or elevators, just pick it off with the paper towels. I start every CA hinge gluing task with a little stack of paper towel pieces. Throw each one away as it is used.
Those flaps were a piece of cake.
RE: HINGE GLUE
suggestions still outstanding..............
Epoxy and CA hinges isn't a real good matchup.
You know how CA hinges sometimes are stiff after the CA kicks off? That won't happen if you continue to flex the joint while waiting for the kick. Not much of a wait. Just flex every so often.
What happens is the CA wicks everywhere inside and across the hingeline both ways and stays in the hingeline where the flex has to happen. If we flex that joint while the CA is still wet, a significant amount is squeezed out of that flex line. If there was a lot in there, that is. So when it kicks, there isn't much in the flexline to stiffen it up.
With epoxy however, it isn't going to squeeze out very well. And the stuff is a gooey, sticky mess that takes skill and luck to get where you want and nowhere else. Flexing the flaps might just get more epoxy into the flexline. And the vaseline deal works with hard hinges great, but really doesn't match up to fuzzy CA hinges well at all. CA hinges have an excellent characteristic. They very often glue the hinge slot back together stronger than it was before the knife sliced it. They glue that split trailing edge right where it needs even more strength now that a hinge is going to be trying to open up that slot. Wipe some vaseline around near there and it'll penetrate both ways from that flexline right into where CA would have been restoring strength and epoxy is going to need help to penetrate.
I've never tried what you suggest with the vaseline on CA hinges because my experience gluing stuff over the years definitely leans away from the idea. I really can't see a way to insure the vaseline stays in a very, very narrow line. And I really don't want to degrade the glue joint down into the slots on either side of that hingeline.
Good thing is that CA'ing the flaps really is pretty easy.
Just remember to epoxy the torque rods in before you CA those hinges. P.S. I help insure the epoxy doing that job doesn't lock the flaps to the wing buy using small pieces of wax paper between the wing and the epoxy/flap. It pulls right out after the epoxy is cured.
RE: HINGE GLUE
Oh yeah, another suggestion.
CA'ing hinges is SO MUCH EASIER if you use a vinyl pipette. So much easier.
(I think MinnFlyer suggests that in one of his reviews, btw.)
My Feedback: (15)
NJ
RE: HINGE GLUE
Thanks da rock. I'll take a close look at it tonight. I have some good analytical pipettes -dont worry. If you say there is enough room to get to the 'underside' of the flap - I'll take your word on it. I really didn't look at it that closely yet as I was still working on the mechanicl retracts. Thanks for all your help and suggestions.
RE: HINGE GLUE
You're welcome.
The only problem I had was holding the wing so I could get to the hinges, the flap open the right amount, the CA pipette at the right angle, and the potato chip bag and Dr.Pepper glass.
You really can't imagine the problem you have explaining the chip bonded to some odd part of your person.
RE: HINGE GLUE
ORIGINAL: da Rock
RE: HINGE GLUE
ORIGINAL: SeamusG
How odd? Lookin' at your avatar ''odd'' could be all over the map ...
ORIGINAL: da Rock
You got dat right...... yip, yip, yip YUP!
What I'd haveta' explain was why I hadn't eaten the chip off my person. And why there wasn't a hole where it had been.
RE: HINGE GLUE
ORIGINAL: newflier1
Can someone tell me what is ''hinge glue''? I'm building a model that has flaps and since the CA hinges are only accessible to one side, the instructions are saying to use ''hinge glue'' and NOT thin CA glue. I have never heard of 'hinge glue'. Can someone tell me if there is a substitute that I can use? Thanks.
Hello , i use Gorilla glue ,great for hinges!!!! try it.
