Windy day plane
TX
Windy day plane
Hey everyone, when its windy and you just got to go fly, what plane does the trick for you? Here in texas if you dont learn to fly in the wind then you wont get to fly much at all, so that being said my personal faverite is my slowpoke sport 40. I just love flying this plane in the wind, we had about a 10-15 mph steady wind today and I flew three tanks thru it. Im trying to add a pic but it wont let me.
My Feedback: (21)
RE: Windy day plane
ORIGINAL: SCOTT42
It was so windy one day, I saw a guy hand launching a twist because it kept blowing over on the runway and he could not take off normally. Once he was flying, he was flying backwards in extremely strong winds. The thing reminded me of birds just hanging aloft in high winds! When he was ready to land, he would just drop it straight down on the ground with about 1/3 to 1/2 throttle. It was amazing
Banned
RE: Windy day plane
[&:] A kite would be good with a very long string.
Seriously, any trainer would be good. When I'm not flying my scale planes because of the wind, people start showing up at my Club with their trainers.
Pete
Pete
My Feedback: (13)
1 Post
RE: Windy day plane
The old Sig Kougar was great in the wind with a knife-like little dihedral swept wing, somewhat heavy wing loading and tough fuselage for those rougher landings.
RE: Windy day plane
Hi GarySS
I too had a SIG Kougar. Loved that plane. It had a .60 K&B. It was great in high winds; tremendous adrenaline rush during landings. However, after many rough landings the rigid foam in the wings would crumble and loosen the landing gear blocks. That was a bad problem for me because I just love to do many landings. Now I only build and fly SPAD planes. My landing gears now can probably take a 6 foot free fall with no damage. Just a couple of days ago I had my SPAD Swept Wing Pusher Canard up on a windy day with plenty of gusts. On the first take off the plane was being buffeted so much that I wished I had not taken off. The first landing went well till a few feet off the ground. A gust rolled the plane past 45 degrees and I corrected and hit the ground at the same time. The prop hit the ground and killed the engine. Zero damage.
My Feedback: (-1)
RE: Windy day plane
My high wind plane was always the 60 size Kaos but any of the pattern type planes are good. 10-15mph is the normal afternoon wind speed in my area so my plane could be anything from an Extra to a Hots?? Whatever I have with me. If you can handle the Poke in high winds you shouldn't have problems with anything.
RE: Windy day plane
Great Planes P51D, with an OS 70 4S.
That plane is made to cut the wind!
We had a Warbird rally last year that had some heavy wind, I was one of three people flying!
(I love an audience )
RE: Windy day plane
Any plane with high visibility. I like flourescent orange strips on the LE. Someone had a plane with flourescent green wings and it popped out really well. Have a clear contrast between top and bottom. You've got to be able to see it really well and orient to it quickly. Good stable ground handling really helps too. My biggest problem with wind is getting blown over while taxiing.
RE: Windy day plane
hi,
I don't mind flying my 40 size stick on windy days. You just have to land nose into the wind. But, for those bad days when I have second thoughts about flying at all due to the high winds here in Illinois I fly my Super Kaos 40.
Frank
Frank
VA
RE: Windy day plane
WIND PROBLEM??
Not forme and.my flying buddy "Crazy George"!! A stash of kites in the trunk of my carwas always available to us when we went to RICHMOND FIELD. Kite"trains" (multiple kites on a single line) and stunt kites (kites controlled by dual lines) kept us flying while other club members were patiently awaiting calmer winds!.
Tony
Tony
RE: Windy day plane
It's interesting to see "old hands" note that almost any plane can be flown in the wind. But I remember vividly a time when I was learning to fly my trainer (SIG LT-40), and a full-scale and RC pilot who was helping me said: "The airplane doesn't 'feel' the wind," implying that it was my job as the pilot to navigate through the "ocean of air" in which aircraft operate.
Well that's true, but to a novice it often seems that the wind sure does push the plane around in ways he may not yet be skillful enough to handle!
This will be especially true when he/she is trying to learn how to take off and land safelyand without damage to the aircraft.
Dzl
Dzl
RE: Windy day plane
You are all right about one thing, if you can't fly in the wind your not going to fly much. Foiled planes handle the wind better than trainers flat bottom wing planes. Trainers are slower and tend to get tossed around more because of wing design. Foiled wings cut the air better and the planes usually fly faster. Any airplane as heavy as the wind speed will not typically be effected by the wind. Having a little stronger engine will also help in over coming wind effects. As far as take off's and landing is concerned, if it's going to get blown off runway then I'm to do something else that day. You ever tried hand launching a 25 lb. plane in a 30 mph wind. That would be fun to watch from a very safe distance. Leroy
Fly safe don't get nuts:
RE: Windy day plane
The two tough issues for windy flying are dihedral and large vertical tail fins, rudders and canopies. All of these produce sudden roll moments from cross winds gust.
Consequently, a stick with no dihedral, minimal box fuselage, no canopy and reasonable vertical stab and rudder area makes for a good windy flier. There are of course other sport designs that fit these criteria.
