I am looking for a straight exhaust extension
Im building a plane with a saito .30 glow engine on it and it has an unusual case where the exhaust pipe goes back inside the fuselage. I am in need of some kind of exhaust deflector like dubro makes only I need one that is straight and doesnt have a slight bend in it. It just needs to somehow attach to the end of the exhaust pipe and be long enough to exit the side of the fuselage which is probably a distance of about 3 inches. Does anyone know where I can find an extension to either fit over the existing exhaust pipe like the dubro rubber ones, or, screws into the existing saito 30 threads?
David G.
David G.
RE: I am looking for a straight exhaust extension
You know, I wonder If I can go to the hardware store and just look for a small piece of rubber hosing that I can just zip tie on the end of the muffler. I think thats all I would need. any suggestions?
