air retracts
WI
air retracts
ok, I need some help . I just purchased a plane form an RC auction and its got air retracts . I know nothing about these systems .
There is a filler valve on the side of the plane but I have nothing small enough to fit it . Even a needle valve (footballs / basketsballs etc ) is too big .
Is there some special kind of pump I need or some special kind of fitting ?
I'm sorry I do not know the name of the manufacturer on the retracts
The plane is a AT-6 Texan and I think its from hanger 9 . If that helps
Any help would be appreciated
Tom
Tom
My Feedback: (60)
AZ
RE: air retracts
Does the fill valve look like the one in the pic below? If it is then it is a Robart item and you can see the (gold) fitting that goes with it which is available from Robart along with a hand pump if you want one. You can also use a standard clamp on type filler like you would use on a bike tire although the threaded Robart unit is much nicer to use.
RE: air retracts
Chances are they are either Century Jet or Robart retracts. Both companies make retracts for this plane. Google these companies and look at the equipment and see if it is similar to what is on your plane. Century Jet retracts for your plane are part number 31688. Sometimes builders will mix different air system parts from these two manufacturers. So look at both and I'm sure you will find the setup that is in your plane. If you post photos of your gear and air system we can probably tell you what it is.
Good Luck. Let us know what you find.
RE: air retracts
Yes there is a special conector that screws into the valve on the side of the plane. You need to know what brand retracts you have as the connectors are different, I believe Robart and Spring Air are the two most commen but there both different. You could just get a Robart valve assembly that comes with the connector and take out the one in the plane if different from the Robart one and replace with the one you bought. As for filling, I use a cheap Harbor Freight 12volt air pump with an air gauge. You will need a short piece of airline tubing, I use a ball inflator needle with the airline pushed over the needle then have the air connector on the other end of the airline. I fill my retracts to about 90-100 psi, and can cycle them 4-5 times no problem.
WI
RE: air retracts
Thanks guys , I'm working on pics . the valve is silver and 6mm outside Dia (or 1/4 inch)
I also need some help Identifying the make and Man of the plane . I thought it was Hanger 9 but its not
W/S is 59 inches and Fuse length is 41 inches
WI
RE: air retracts
I've been looking on the net and I think it might be a Kyosho but I can't find a good pic of it . It has been disc (my luck )
What is "spring air " vs "air" and I still need to find something to try and fill the system.
WI
RE: air retracts
I've tried calling "spring air Products " several time and had to leave a messege . So far I have not got a call back . I also emailed them twice , so far, no response
RE: air retracts
You can use any style 12 volt air pump with a cam lock connector to charge the air system. Find one of those hand held emergency air compressor/emergency light units typically intended to keep in your car for "just in case". There are many on the market. Home Depot has Campbell Hausfeld, Sears has thier own, Walmart will have them in the auto section. You slip the connector onto the receiver fitting on the side of your plane, lock it in place with the lever on the connector and start the pump. Your 12 volt starting battery will power it.
My Feedback: (34)
RE: air retracts
wldhair,
definately spring air retracts. The gold color is their trademark.
The diff is they use a single air line to "pull the gear up" against the resistance of a spring inside the air cylinder. if you should loose air pressure the spring forces the gear down and thus you can land on the mains.
Some older air systems like RHOM-AIR and some today still use two lines and lack this saftey feature.
Thus the servo operated valve is very simple.
If you desire a slower speed, I have always used wheel collors and adjust the set screws. That is until the darn expensive valves came out. But something said for the simple solutions still.
Take Chads (post#2) picture down to you local Hobby shop and swap out the filler valve as the robart ones pictured have always worked 100% for me. Use a hand pump or electric roadside that has a gauge to 120. Fill to about 100-105 PSI.
Good luck.
Good luck.
WI
RE: air retracts
Hey Firebee
Thanks for the info . I've still not been able to contact "spring air " but I'll keep trying .
I swapped out the filler valve and ran across another problem - maybe you can hep .
The "schrader valve" inside the filler valve is too short and will not depress when I attach the pump and therefore will not let the system accept any air .
I swapped out the shrader vlave to went to a "long " schrader valve hoping that would solve the problem but the long shrader vlave is too long and one thats mounted in the filler valve the valve won't open ....
Soooo the orig valve isn't long enough to be activated by the pump attachment and the long shrader valve is too long and won't depress when pump is attached ........hmmmmm
I tried unscrewing the shorter shrader valve to the point where it will accept air into the system but as soon as the pump is removed all air leaks out of the fill/shrader ....
I've never had retracts before and this is becoming a real nitemare lol
We were able to get air into the system and they DO work - now I just have to figure out how to fill the system so it won't leak
Any Ideas????
Tom
Any Ideas????
Tom
My Feedback: (34)
RE: air retracts
Wldhair,
let me check my parts box tonight. I will send you a PM if I found I have a working switch.
I also had problems contacting Spring Air. They apear to be a more "mom and Pop" store and would only respond once in a blue moon. But their retracts are great!
WI
RE: air retracts
Hey Firebee
That would be great as I still have not heard from Spring air -
I was messing around with it last nite and was trying to get an air line off to use to try and use as a filler tube with a needle valve (foot ball -basket ball filler) and in the process I broke a little plastic "T" valve for the air line ...grrrrrrrrrrrrrrrrrrrrrrrrrr My LHS had to order it so I won't be trying anything till at least Sat .
I talked to a friend of mine ,who been flying for a long long time and he said the orig schrader valve should work but without seeing the set up - thats about all he would say (he lives 40 miles away ). As a last resort , I may end up hauling it over to his house but I honeslty do see how its gonna work - there must be some kind of adapter for either the pump or the valve ...... I'm stumped LOL
BTW the set up I have is exactly the one that Chad has pictured on this thread (scroll back)
RE: air retracts
I've got 3 Spring Air retract sets and like them very much. However, due to many hot, fast, landings on a short, hard, asphalt runway I need to change out my struts. I've ordered beefier struts from Spring Air (3/16") but they don't mail them to me......even after paying for them and calling them back. They claim they're backlogged with other work (200 pairs of retracts, and the machinist supplying parts is not delivering the goods).
I'm getting ready to hire my own machinist to make parts. All I need is the little round cylinders that fit into the retracts. I can get the struts and axles from Tower Hobbies.
