Striping Tape
AR
Striping Tape
Who has the best selection of striping tape? I'm looking for a variety of colors in widths of 1/16, 1/8, 3/16 and 1/4 inch. It seems the 3/16 is harder to find than the others.
AR
RE: Striping Tape
Hey Gene, I use a stripe cutting machine also for cutting MonoKote stripes and putting on either MonoKote or UltraCote, but I am striping an old plane that I picked up just to experiment with Koverall. This thing is covered with Koverall and painted with house paint (latex). I was not sure if MonoKote stripes that I cut would work over latex and if it would, should I use heat to apply. So I started striping with some Carl Goldberg tape that I already had. I got the wings done and ran out of tape. Then I discovered that I can't find any 3/16" tape anywhere and that is what I used on the wings. I could probably use 1/4" on the fuselate and nobody would notice the difference in width, but I am kind of weird about trying to keep things the same.
RE: Striping Tape
The auto striping tape should work for you. You probably can find it in the same color as your Goldberg tape. It most likely comes from the same factory.
If you can not find the same width, I suggest that you buy smaller width tape, not larger. The fuselage is a more confined area. In my opinion, the smaller tape looks better.
My Feedback: (-1)
RE: Striping Tape
I have never tried to run a heat gun over latex so???????? I ran into a problem with the stripe tape I bought in hobby shops. It hangs on the wall so long the glue is bad. Then I just got the tape at the auto parts store and there is a bigger turnaround because I haven't run into the problem. The local auto parts store also has a much bigger selection.
I found my cutter at a club swap meet for just a couple bucks. I have always just used a ruler. After I set it up, sharpened a blade for it and gave it a try I discovered I have been cutting my stripes the hard way all these years. For the people that cover there own planes the cutter is one of those tools that is worth the price. Sure does a nice job and I have cut stripes down to a 32nd, even smaller by accident when I was just fooling around.
I'm thinking Latex for my next plane. Cheap, easy clean up and I can get the colors matched at any good hadrware store.. Only good for gas, not glow!! So I'm told.
AR
RE: Striping Tape
Gene, yes it is a Great Planes Super Aeromaster. I traded for it wrecked just to play with. It appeared to be covered originally with Koverall so that's the way I went since I had been wanting to try it anyway. And I believe you can use any fuel with latex if you spray it with a glo fuel resistant clear coat. I'm gonna try it anyway.
My Feedback: (-1)
RE: Striping Tape
I just loaned out an article on painting with Latex to a friend and yes, you can spray a clear coat over it but as a stand alone paint it isn't fuel proof but great stuff for gas powered planes. I just traded away an Aeromaster. More of a give away. A fellow gave me an engine and I felt guilty so I gave him a plane. A very nice engine!!!!!!!!
AR
RE: Striping Tape
Engines and planes are like gravy and bread. They never come out even. Right now I need several four strokes for kits I have to build and I can't afford them.[]
