Reload this Page >
muffler question
muffler question
Old 04-08-2011, 11:25 AM
andizzle
Default muffler question
just put a super tiger 40 on my ultra sport and the hose from the tank to the muffler is to short, can i drill a new hole on top of the muffler, tap it and put the nozzle there and just put the screw back in the muffler where the nozzle was at?
picture of my problem
Old 04-08-2011, 11:46 AM
landeck
Default RE: muffler question
Why not just replace the tubing with a longer one? Or add a short length to the existing one coupling them together with a short 1/8" brass tube?
Bruce
Old 04-08-2011, 03:33 PM
Gray Beard
My Feedback: (-1)
Just lengthen the hose a couple of inches like Bruce mentioned.
Old 04-08-2011, 05:15 PM
tacx
tacx's Avatar
I suggest you just lengthen the tube as others have said. If you notice where your nipple is tapped into the muffler there is a shoulder to make the metal thicker at that point. If you drill a hole elsewhere and try to tap it you may not have enough thickness to make it work.
Old 04-08-2011, 06:35 PM
JohnBuckner
JohnBuckner's Avatar
ID:	1591183   Click image for larger version
Old 04-09-2011, 09:12 PM
andizzle
thanks guys i ll go with the adding to the fuel line, i cant get to where it attaches to the tank to add a longer line
Old 04-10-2011, 07:07 PM
Charlie P.
Charlie P.'s Avatar
ORIGINAL: andizzle
Is it pressed against the inside of the cowl or the engine? If so, keep a close eye on it for wear or tearing at the nipple and contact points. If it's so tight it's kinked - change something.
