Table top band saw
Table top band saw
Need to get a saw for the workshop and I think the most versitle and used is the band saw . What is the best to buy for the money . Space is limited . Thanks Ken
My Feedback: (14)
IN
RE: Table top band saw
If you can, buy a variable speed version. A band saw is really overkill for most Balsa. Variable speed will allow you to slow it down, which will help not destroy balsa and also give you the ability to cut metal. I have a 12" floor model band saw, and do almost all my cutting on a 40 year old Dremel scroll saw. It's easier and accurate.
Nothing handier than a band saw for building. If you decide on a tabletop version, stay away from the ones with 3 wheels. They tend to break blades easily. Mine did. I made a rip fence and mitre jig for mine and use it like a tablesaw.
My Feedback: (-1)
I have always used a scroll saw for my kit cutting. A kit includes a lot more then just balsa but they work very well for my use. Last week I cut a kit and posted it in kit building but this time I went to my wood working club and used a band saw. It was a lot quicker and easier then using my scroll saw. I cut a complete kit for an 80 inch Sukhoi in one hour and 40 minutes. Quite a bit quicker then my scroll saw. If you go to or look up Harbor Frieght you can find some good deals on both band and scroll saws. I have a small table top band saw but it just doesn't have the power for thicker wood.
One thing I would advise is buy decent quality. I bought one at the Home Depot at a price that sounded to good to be true. Gues what? It is a piece of junk. Ihate it. I am not saying to go out and buy the most high dollar, professional woodworkers saw either. Just something a step up from the bottom.
You'd be surprised at what is on Craigslist and at garage sales. You might get lucky and find an older bandsaw from back in the day when they were built out of some serious metal.
Igot my scroll saw from a guy who bought a truckload of returned Sears merchandise. It had been dropped and the the plate that covers the end of the motor was bent and rubbing on the motor fan. A few taps on the plate with a hammer and it works perfect.
AR
I use a scroll saw a lot. Next item to purchase is a belt/disc sander. I have access to a band saw if I need it, but I haven't had the need yet. I intend to cut my own wood and build from plans soon but I still think I will use the scroll saw in preference to the band saw. I do see a need for the sander to do this though.
I have a Ryobi that cost around $100 at Home Depot. On thing to look for is a smooth surface where the wood will be. My brother had a Delta and it had grooves that made it hard to slide small sticks around.
I have the [link=http://www.craftsman.com/shc/s/p_10155_12602_00921400000P?vName=Power+Tools+%26+E quipment&cName=Power+Tools&sName=Bench+Power+Tools&prdNo=8&blockNo=8&blockType=L8#custReviewsWrapper]Crafstman 10" band saw[/link] and it is one of the most used tools in my shop along with my [link=http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10051&catalogId=10053&productId=100061671&R=100061671]Ridgid oscillating sander.[/link]
I caught the band saw on sale for $109.99
