Engine size
My Feedback: (-1)
RE: Engine size
A lot depends on the engines too. These days the new four strokes have come up on power so there is no set rule of thumb to compare. I have an older OS 1.20FS that has been rebuilt but still doesn't have the torque of the newer ones. I have several of the older YS 1.20s and you would be hard pressed to find a .90 two stroke that can pull a plane around as well as any of them. With most bipes you usually need the added weight in the nose too, I would rather have it engine weight instead of lead.
