Voltage regulator question
My Feedback: (17)
MS
I have an application that requires 7.4v (designed for lipo)but I would like to use an A123 battery instead. The problem is that the A123 cells are 3.3v so I will have to use a 3 cell pack (9.9v) and regulate it to 7.4v in order to get the required voltage. It seems that all current voltage regulators are designed to reduce 7.4 volts to 5 or 6 volts so lipos may be used as receiver batteries. Does anyone know of an regulator that would work in this situation?
NY
RE: Voltage regulator question
I have not seen a 7.4 regulator. I use 2 cell A123 in large planes ( .60 and up) for receiver packs. The extra weight and bulk make them unsuitable for small planes. If you are powering a motor, it may be OK as is if your motor can handle a 3 cell lipo.
RCU Forum Manager/Admin
My Feedback: (9)
You might want to ask this question over in the RC Jet's forum. More than likely somebody over there has already tackled this issue and will have an answer for you.
Ken
Ken
you need a lm338 google it. is like the radio shack lm317, but the package at R.S, for the lm317 has the wring diagram wrong. use the diagrams from the Internet.
My Feedback: (17)
MS
Thanks for the info but I don't think I want to try and build a regulator. My soldering skills arelimited to Dean's connectors I was hoping to find a manufactured one.
