Reload this Page >
Servos and plane...
Servos and plane...
Old 06-29-2011, 02:53 AM
guille2006
guille2006's Avatar
Default Servos and plane...
Hi all; i wonder how this servo http://www.servodatabase.com/servo/futaba/s3150 could match that plane (see photo). I've 7 of those servos there NIB, waiting for to be mounted... Rudder will be a HS-645. Engine will be the new Mintor 33 Gas...
Thanks on advance!!!
Old 06-29-2011, 03:42 AM
BarracudaHockey
BarracudaHockey's Avatar
Default RE: Servos and plane...
51oz of torque on a gasser aerobat? I certainly wouldn't do it.
Old 06-29-2011, 04:08 AM
guille2006
guille2006's Avatar
And what about HS-422? Anyway; what the less you'd advice?
Old 06-29-2011, 06:58 AM
jester_s1
Moderator
The manufacturer should have recommendations for servo torque. You might do a search for your particular model to see what others are running. A lot of the choice depends on how you plan to fly it. Loops and rolls don't require as much servo as 3D does.
Old 06-29-2011, 07:48 AM
jetmech05
the servos you are wanting to use seem weak to me.......you should be able to find the servo specs somewhere or e-mail the manufacturer
Old 06-29-2011, 10:35 AM
The MacDaddy
My Feedback: (10)
The MacDaddy's Avatar
In general if the mfg doesn't tell you the requirements, you should have at least 1 oz-in of torque for every square inch of control surface, minimum.
Old 06-29-2011, 04:22 PM
Gray Beard
My Feedback: (-1)
I know in Italy the prices will be different but do yourself a favor and go onto Servo City's web site and just look at the servos and different power you can get for the money. Karbonite gears are not wanted in a gasser but neither is a servo for only 4.8 volts. Just read up on the different servos and you will get a better idea of what you would want. That looks to be a 1/4 scale and the servos you have may be just a bit light. Use the biggest servo you can on that rudder.
Nice looking plane too!!!
Old 06-29-2011, 11:09 PM
guille2006
guille2006's Avatar
Well, thanks for the comments; I get for this plane 5 Hitec HS-645MG; torque @4.8V: 106.9 oz-in (7.70 kg-cm); about U$S 27 each in TH.
