Reload this Page >
Wire wrap and solder control rod linkages together.
Old 07-06-2011, 07:25 AM
Jim_Purcha
My Feedback: (8)
Default Wire wrap and solder control rod linkages together.
Hey guys. I want to wire wrap and solder two pieces of 2-56 music wire together. What guage of steel wire is used to wrap around the music wire?
Jim
Old 07-06-2011, 07:28 AM
ARUP
Default RE: Wire wrap and solder control rod linkages together.
Get some copper wire that is used in crafts. Works like a charm!
Old 07-06-2011, 10:20 AM
big max 1935
My Feedback: (9)
I like 1/8" ID brass tube flattened some so both rods will slip in . You can make your adjustments & then solder. Neet looking. Max H.
Old 07-07-2011, 06:22 AM
LesUyeda
Banned
And if you pre-tin your music wire first, it will simplify the task considerably.
Les
