Futaba 7C Fasst
My Feedback: (65)
Futaba 7C Fasst
Hi guys
on the 7c futaba transmitter when using 2 servos on elevator 1 on each half and plugging 1 in to elev.ch and 1 in ch.5 and use mix to make them work together. OK hears the question when you trim the elevator on the transmitter only the side plugged in elev. ch. moves, so is there anyway to make both sides move together without having to use subtrim for the other side.
hope this makes sense and someone can help me out or do I just have to buy a higher end radio.
thanks for any help.
RE: Futaba 7C Fasst
If it's not a 7C FASST transmitter, then you cannot get both halves of the elevator to work with trim. Only the elevator channel will trim, and it doesn't carry into the mix. As said above, the 7C FASST transmitter has the Ailevator function, which does allow trimming of both elevator halves.
