Reload this Page >
DLE 30 and prop
DLE 30 and prop
Old 07-16-2011, 01:58 PM
indgroove
Default DLE 30 and prop
Hello, I have a DLE 30 and a Xoar prop for it. A 3/8 drill bit is slightly smaller then the shaft of the DLE. Will the 3/8 drill bit work or do I need a metric drill bit (is there such a thing as a metric drill bit?) The local hobby shop doesnt deal with gas engines so they counldn't help.
Thanks for your input.
Ind
Old 07-16-2011, 03:00 PM
scooterinvegas
scooterinvegas's Avatar
Default RE: DLE 30 and prop
ORIGINAL: indgroove
Dude....
Go to Tower Hobbies and order a metric reamer.
http://www3.towerhobbies.com/cgi-bin...?&I=LXEGH6&P=8
Old 07-17-2011, 02:43 PM
The Ghost
The Ghost's Avatar
ORIGINAL: indgroove
Ind
You will require a 10mm drill bit and a 4mm drill bit to drill the prop for the DLE30. The reamer will do the job also.
Cheers
