needle valve for Torpedo .32
RE: needle valve for Torpedo .32
Yes I do. You may have to space it out with a few washers on both sides to center the jet in the venturi. For this fibre washers work well.
Torpedos were made by K & B and went like stink but did not run a good 2/4 break like the Fox's did. Mix some caster in your fuel to bring it up to roughly 25% total oil.
John
John
