High thrust for 70mm EDF HELP !
ON, CANADA
I'm curently working on a EDF V-TOL Aircraft & need to Know How to Acheive maximum thrust on 70mm Unit. Is it the # of fan blades, Motor with high KV or low KV What combo would be best. I'm looking to reach Around 5-6lbs of thrust for boath Edf units. Have no Clue where to start & need a Decent power plant. Can anyone help.
My Feedback: (7)
OH
RE: High thrust for 70mm EDF HELP !
Slybird,
The H.E.T. Typhoon Brushless EDF 2W-25-75A Drive Set Plus puts out 1000+ watts on six cells and just over 4lbs.
If you really need to be in the 5-6lb range you will need to look at Schubler and some serious cash.
