du-bro hinges
My Feedback: (10)
du-bro hinges
hi
i like to use Dubro Heavy Duty Hinge & Cotter Pin #257 on my usa balsa citaba the trouble i see is that the barrels of the hinge keeps the parts i think to far apart i can put them in a little but the gap is still there i dont want to start having flutter on the controls and i dont want to seal the hinge line ,any ideas? thanks rye
My Feedback: (-1)
RE: du-bro hinges
I often use the DuBro flat hinges and like them a lot. My kingdom for a couple of bottles of Pacer Hinge Glue!! I use a small burr and cut a round counter sink along the hing slot so i get a very tight hinge gap. Depending on the type of TE and LE decides what type of hinge I will use. I often mix the flats and the hinge pins on the same plane. I build all my planes so I am able to add wood along the LE and TE so I get more wood for the hinges to go through. I also use the GP Hinge Slot Cutter for the flat type. It's sort of like using the easy button.
