If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 10 of 10
  1. #1
    Join Date
    Dec 2003
    Derby, KS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Brazing vs Silver soldering
    I want to do one or the other for some simple music wire landing gear. Which is better? Is either easier than the other? I have some brazing rod with flux coating and would use my butane torch, or try and use the torch with the silver solder. Thank You in advance for your opinions.
  2. #2
    Join Date
    Nov 2005
    Auckland, NEW ZEALAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Brazing vs Silver soldering
    Use fuse wire binding and soft solder. Brazing or silver soldering will take the metal beyond the critical temp and the wire will harden and break on the first landing.
    Evan, WB #12.
  3. #3
    Join Date
    Dec 2003
    Derby, KS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I gotcha on the soft solder. I have the copper wiring. Would rosin core solder be considered soft? If not, recommendations, please? Thanks again.
  4. #4
    Join Date
    Jan 2002
    Ivyland, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yes, electrical solder and plumber's solder are considered soft solder. Either should be fine provided that you make a good mechanical connection before soldering.
    Glow Head #6, UltraSport #70
  5. #5
    Join Date
    Mar 2006
    Lebanon, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Stay Brite is abetter solder to use as is contains a small amount of silver. so it is stronger than regular solder
  6. #6
    Join Date
    Nov 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just make sure you wash the flux off after soldering. The rosin core wont corrode, but most other solder fluxes have acid in them and this needs to neutralised. I use a quick wash with boiling water...
    Evan, WB #12.
  7. #7
    Join Date
    May 2004
    Mission, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Radioshack sells a solder called silver bearing solder. It has a higher silver content than the typical electrical solders sold. Needs a good high temperature iron but is much stronger that most solder types typically available.
  8. #8
    Join Date
    Apr 2009
    wichita, KS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    if you need an easy way to stop the solder, just take pencil and mark the area that you dont want the solder. you can solder/braze up to it and stop. but you can force past the pencil mark if you really want.
  9. #9
    Join Date
    Dec 2001
    Upplands Vasby, SWEDEN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi!
    As has been said earlier...brazing or silver solder will not work on piano wire as it softens the steel rod.
    Best metod is to use sweet solder and reinforce with some kind of thin wire, copper or steel.
    Best solder to use is "Stay Brite" as it contains a flux that makes soldering soo easy (very corrosive) and a solder that contains silver which make the soldering joint much stronger than ordinary thin/lead solder.
    Jan Karlsson - Supplier MVVS Products
  10. #10
    Pylonracr's Avatar
    Join Date
    Apr 2011
    Reno, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Most plumbing solder has silver in it now, as they are trying to remove lead from our drinking water. The better plumbing solders have a lot, and require much more heat. Read the label for melting points.
    Revver Brother #260
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
