If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 66
  1. #26
    AmishWarlord's Avatar
    Join Date
    Oct 2002
    Indian Trail, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: RotoFlow clunkless fuel tank
    As per recommendations by John and Greg I got an 11oz Hayes tank to try out on my engine test stand.
    Looks like I'll be switching brands of tanks. LOL
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  2. #27
    foodstick's Avatar
    Join Date
    Mar 2005
    ankeny, IA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I use only gasoline engines now, and I like the dubro tanks, But I would LOVE if the opening was about twice as big where the bung inserts in the tank.
    Self taught with Sig Trainers, and weaned on Balsa USA WW1 kits.. BUSA Brotherhoods #112 !
    "Friends til cinders"
  3. #28
    Join Date
    Jul 2005
    , TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    For those new to the hobby, Hayes and Kraft fuel tanks are one and the same. Chuck Hayes
    worked for Kraft, and designed many of their molded products, including I believe several
    of their servos. His designs, in many cases were ahead of their time, and are still used 40 years
    later. My question is "who owns the fuel tank line now?" Greg
  4. #29
    Join Date
    Oct 2002
    Indian Trail, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
  5. #30
    Join Date
    Jul 2005
    , TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for the info. Greg
  6. #31
    Join Date
    Jan 2002
    Eldon, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: jester_s1
    Looks like an engineering student got bored and created a solution to a problem that does not exist. A properly set up standard tank does not foam, does not get the clunk stuck forward, does not leak, and does not bubble.
    DITTO!
    Count me in as another long time Hayes tank fan.
    McDDD
    ProBro 415
  7. #32
    Join Date
    May 2002
    Portland, ME
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have used one in two airplanes now with no problems... another advantage is if no seal problems develope you don't have to worry about the tygon tubing needing to be replaced at least every year... some times more often... Bill
    Bill Lairsey
    Portland, ME
    Maine IMAC Chapter 82 Rep.
  8. #33
    Moderator
    Join Date
    Dec 2006
    Fort Worth, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Wow Bill, you missed resurrecting an exactly year old thread by just one day!
    No kid, I said break ground and fly into the wind!
    RCU Beginner's Forum Moderator AMA 891050
  9. #34
    Join Date
    Jan 2004
    Bourbonnais , IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Been using Hayes tanks for years, they are the best. Will do almost anything to replace cheap arf tanks with a Hayes, sand formers, mod sheeting, etc etc. Always well worth the trouble. Have solved others "engine" problems just by replacing their tank with a Hayes. Once you try them you will never go back. Oh yeah it takes about 30 seconds to assemble one, no tube bending, no stopper screw, no leaks, never uderstood why some guys just have to have the ones with tubes and stoppers?
  10. #35
    Join Date
    Oct 2002
    Indian Trail, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Wish Hayes made lager tanks like 24oz.
  11. #36
    Join Date
    Nov 2007
    Sandy Springs, GA GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: k3 valley flyer
    Been using Hayes tanks for years, they are the best. Will do almost anything to replace cheap arf tanks with a Hayes, sand formers, mod sheeting, etc etc. Always well worth the trouble. Have solved others ''engine'' problems just by replacing their tank with a Hayes. Once you try them you will never go back. Oh yeah it takes about 30 seconds to assemble one, no tube bending, no stopper screw, no leaks, never uderstood why some guys just have to have the ones with tubes and stoppers?
    About 2/3 of my planes have cowled in engines requiring a three line fuel system. With the Hayes tanks the thrid line can only be used for fueling the plane; it can not be used to empty the fuel tank. Otherwise they are good tanks.
    Bruce
    Bruce L. AMA# 54227
    Ultra Sport Brotherhood #15
  12. #37
    Join Date
    Jul 2005
    , TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    TURN YOUR AIRPLANE UPSIDE DOWN, AND YOU CAN USE THE THIRD LINE TO EMPTY YOUR TANK.
  13. #38
    Join Date
    Jan 2004
    Bourbonnais , IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Most of my 32 planes are cowled also, but have never been a fan of three line set-ups. I have no argument with those that perfer them, just not for me. I use some type of filler with a small hole in the cowl to reach the filler. Even a three line system usually has to have a hole in the cowl for the fuel dot etc. Now some guys perfer three lines over a filler and that is fine. I just never liked two clunks and plugging that third line. I am sure both methods have pro and cons. If Hayes made a tank that would work with three lines better might try it. With two lines and a filler the fill and drain issue with one clunk is solved. But fuel dots look nice on scale planes.
  14. #39
    Join Date
    Jan 2011
    SorrentoBritish Columbia, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have been using the Hayes tanks for a while now and I really like them..They are way easier...I was a bit worried they might leak at first but so far I have had no problems whatsoever...They work great but I havent tried them on my gassers because I worry about the leaking thing..They just dont feel as tight...Does anybody else use them for gas?? I have been thinking about trying a Roto Flow Tank Just So I would know A bit more about them..I even sent them a E Mail with a few questions ..How come nobody is carrying these tanks? To expensive??They are awfull pricy....I dont think I really need one of their tanks , I just want one. Its Just Bling Bling..I am kind of like a Crow I like shiny things....Thanks to SigMan for bringing this subject up...
    Ken , Biker BC Cub Brother #6 Ultra Sport Brother # 100 Tiger Club # 7 Pulse Brother # 1 Sig Brother # 58 Top Flight Brother # 9
  15. #40
    JohnBuckner's Avatar
    Join Date
    Dec 2001
    Kingman, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: bikerbc
    Yes I use them on virtually all my fifty odd aircraft with the exception of a few bubbless tanks for certain airplanes. And yes in the gassers, the 16 ounce is plenty for my flights which are typically around eight minutes. Finally there is not a third line setup in any of my airplanes or is it missed and yes many are close cowled. The two line setups are even better and quicker to de/refuel.
    Both of these are fifty cc gassers both on 16 ounce hayes and both two line with zero problems defueling, even easier than defueling with a third line.
    Oh ya, forgot my Big Buck built in 74 its a gasser refurbished in honor of the original builder. Its also a gasser and now uses a Hayes.
    John
ID:	1804091   Click image for larger version.
ID:	1804092   Click image for larger version.
ID:	1804093   Click image for larger version.
ID:	1804094   Click image for larger version.
    \"Keep your controllines tight\"
  16. #41
    Join Date
    Jan 2011
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks John I am going to start using them on my Gassers too...They are so easy to use...I am building a BUSA 1/4 Cub with a 160 Gemini in it and thats what I was thinking about using the Roto Flow tank in...This plane is going to break the bank anyway...
  17. #42
    Join Date
    Dec 2001
    Kingman, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    You are welcome and fears of the hayes leaking is pretty much a non event and certainly not the problem conventionals can be.
    I've never tryed the roto flow but it certainly looks like it could also do the job well.
    Back in January at the Ontario show I talked with some of the Hayes folks at their booth and of course inquired about a larger tank. The response was bleak as the cost of new molds would be prohibitive for the projected sales from a new large tank.
    John
  18. #43
    Join Date
    Jan 2011
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    John How do you have the two line set up...The vent line runs out the bottom...The clunk line has the little filter break by the cowl where you fuel and defuel . Does that sound about rite?? Could you draw a pic?
  19. #44
    Join Date
    Jan 2011
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    John I love Arthur's Airplane Is that some sort of add on ail on the left hand wing? I dont see anything on the right hand wing...
  20. #45
    Join Date
    Dec 2001
    Kingman, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Look at the picture of the yellow airplane with the fueler hooked up. Yes the tanks vent runs out the bottom and you can see it in that picture. The clunk/carb line is the one that run out/in the cowl and is separated there where the pump is hooked up to push fuel into the tank untill it runs out the vent just like a trainer or you pull the fuel out (defuel) with the pump. There are only two lines that go into the tank not three as there would be with a fuel dot.
    The only differance with the glow engines is the vent line is just hooked up to the muffler. You still fuel and defuel from a break of the clunk/carb line which makes a small loop out/in the cowl.
    Also in the case of cowled two stroke glow engines that simple loop in/out of the cowl gives that all important place to do the 'pinch' when one chooses to tune to a pinch. Something I make every effort to teach every student or anyone who will listen.
    John
ID:	1804101   Click image for larger version.
ID:	1804102   Click image for larger version.
  21. #46
    Join Date
    Nov 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: GREG DOE
    That will still leave a good amount of fuel in the plane unless you turn the plane on its nose at the end. I know because I have tried it. In the end I just find it clumsy - that is my personal feeling.
    JohnBuckner, you have shown that approach a number of times. I tried it on a plane many years ago and just did not like how it looked.
    k3 valley flyer, if you are talking about the DuBro quick fill valve,
    http://www3.towerhobbies.com/cgi-bin...&I=LXD745&P=ML
    I have tried it twice and in the end found that the O-rings began to leak or the valve began to stick resulting in engine problems. I have not tried their new valve.
    Only two of my current 13 flying planes do not use a standard three line system with two klunks and fuel dot. I find that that works fine for me, never gives me a problem, and looks good. The only problem is that on those planes I can not use the Hayes or RotoFlow tanks which I agree are good tanks.
    Bruce
    Bruce L. AMA# 54227
  22. #47
    Join Date
    Apr 2003
    Hemderson, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I broke down and let John talk me into a Hays tank a couple years back using a YS engine. My thinking was the YS could pop out the cap. It hasn't and it hasn't leaked at all either. Any time I use a two line tank I go directly to the Hays tank now days. I have more problems finding them in any of my LHS though and I don't do enough mail ordering to bother just buying tanks. With the YS engines I can just use a Tee in the main line to fill and empty. They work pretty well, wish I could find a good source of sizes in my area.
    I have also met a fellow using that new tank and it broke inside, you can't repair it when they break.
    Drinking and driving are illegal, why do bars have parking lots
    Daisy Air Guns, keeping kids off your lawn for 100 years
  23. #48
    Join Date
    Dec 2001
    Kingman, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: bikerbc
    Ah Yes I totally love that magnigicient old Buckineer. That covering and paint is the original put on in 1974 and it is Ceconite 103 the lightest grade full scale synthetic fabric and its still in great condidtion. Arthurs orginal AMA owners tag is still inside the airplane with his address in Idaho at the time.
    That single piece wing sticks four feet out the back of my truck along with the entire tail when transporting and is lightly built. Every time when I reach the field that end of the wing just warps so I added a fixed trim that takes care of that problem. It even changes during the course of the day. It is hinged and I added a dead ended pushrod with clevis at both ends and that allows all the adjustment needed.
    Here is a picture of Arthur about seven years ago on his last trip to the field at age 92 I beleve, he pased away several weeks later. He is holding the last airplane he ever built but was unable to complete, a Sig kit TriStar that I had the honor of completing and was able to fly it for him several times that day.
    John[8D]
ID:	1804104   Click image for larger version.
  24. #49
    Join Date
    Dec 2001
    Kingman, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: landeck
    Ah Yes Bruce its the old 'Beauty is in the eye of the beholder' thing. But for me functionality (a beautiful thing) trumps beauty every time
    John
  25. #50
    Join Date
    Oct 2002
    Queensbury, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: landeck
    The problem I see with it is that there is no way to add a second interal line for fueling/emptying the tank on cowled engines. Also it is pricey and I question reliabiltiy.
    Bruce
    If you read about the product in full, you will find that a second line is easily added. Pricey maybe, but do you know anybody that has taken their cash to heaven ? Reliability is total, from what I have been told.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
