RotoFlow clunkless fuel tank
Reply
Old 09-23-2012, 11:10 AM
  #51
landeck
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: RotoFlow clunkless fuel tank
Quote:
ORIGINAL: Granpooba
Quote:
ORIGINAL: landeck
The problem I see with it is that there is no way to add a second interal line for fueling/emptying the tank on cowled engines. Also it is pricey and I question reliabiltiy.
Bruce
If you read about the product in full, you will find that a second line is easily added. Pricey maybe, but do you know anybody that has taken their cash to heaven ? Reliability is total, from what I have been told.
Yes, a third line can be added externally but a second line with klunk can not be added internally.
Bruce
landeck is offline
Old 09-23-2012, 11:46 AM
  #52
chris923
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I and serveral friends have been using Roto-flow tank for 3 years now ( We got some of the orginal ones, we know JL Products).
Combined gas and glow flights, over 150. No issues. They are a little heavier, so if weight is a big problem,
stick with water bottles. For warbirds they are great. They also will take a beating. I had a plane on in
at full speed. About the only thing that survied was the tank.
When possible I use them, no more stiff clunk lines!
Chris923
chris923 is offline
Old 09-23-2012, 12:05 PM
  #53
Gray Beard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: JohnBuckner
Quote:
ORIGINAL: landeck
JohnBuckner, you have shown that approach a number of times. I tried it on a plane many years ago and just did not like how it looked.
Ah Yes Bruce its the old 'Beauty is in the eye of the beholder' thing. But for me functionality (a beautiful thing) trumps beauty every time
John
Not to mention you can put the split line any place you like so it is out of site. Most my planes have had a Du-Bro and three line with a dot. No problems with them either. Tank set up is just a personal thing, I use what I think will work best in each plane.
I may not be able to take it with me but I can spend it on something I need and want. I really haven't had a lot of fuel tank problems over the years. If you have deep pockets and want to try something different then by all means give it a shot. I would rather have a can of Klass Kote paint then spend it on a new fuel tank. I'm in need of paint!!
Gray Beard is offline
Old 09-24-2012, 03:45 AM
  #54
airega1
airega1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: AmishWarlord
This reminded me of a system I saw in a Tips and Tricks book.
You take the clunk and solder it on to a length a brass tubing that is 1/4 inch from the back of the fuel tank and 1/2'' to the tube sticking out of the bung. You use fuel tubing to connect the clunk ''wand'' to the bung tube. Worked great. I had forgotten about it.
WHOA WHOA! WHAT A GREAT IDEA, (post 20) THANKS FOR SHARING,WARLORD, I CAN SAVE ON ALL THAT EXPENSINE GAS TUBING. Just can't get enough education.
airega1 is offline
Old 09-24-2012, 04:03 AM
  #55
dingo9882
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
After seeing this I am probably going to purchase one. I have a P-47 that is by far the worst plane for me to change the gas lines in every year. I have to pretty much remove the servo tray, the engine, and some other stuff just to get to the tank. This will pretty much solve the issues and all the time it takes for me to just change the lines.
dingo9882 is offline
Old 09-24-2012, 04:13 AM
  #56
JohnBuckner
JohnBuckner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: airega1
There is a price to pay for that old trick and it is worse if you need to use tygon fuel line with a gasser. It is directly related to the size of the fuel tank, the amount of flex gap you use and the type of fuel tubing you need to use. Its so easy doing this that the clunk can no longer fall to the top of the tank when inverted. Now on an old timer that may not be a big issue but an aerobat it certainly is.
John
JohnBuckner is online now
Old 09-24-2012, 06:53 AM
  #57
jaka
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi!
Try a Tettra tank!
jaka is online now
Old 09-24-2012, 08:47 AM
  #58
gade600sdi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think some of you guys are way overthinking this. Looked at the first few posts here and they made a lot of sense to me. Dubro tank or Fiji/Soda bottle. This roto thingy tank is too heavy, too complicated, too expensive and unnecessary. Keep it simple, this complicated tank, although an engineering maserpiece, is a waste of money. Third line not needed, use a dot. Simple. Cheap. Effective. Works all the time. Leave gas in your tank to keep the Tygon soft. Put a plug in your vent line for fumes or spillage prevention. Simple safe, effective. I laugh at the post above, about the guy that crashes a plane and the roto tank is all that survives. At that point does it really matter, really? So if I crash my $3000 Sukhoi and I get a crack in my $8 Dubro tank I should be upset and sorry that I didnt buy a roto tank?
gade600sdi is offline
Old 09-24-2012, 09:04 AM
  #59
gwweber
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have tried the roroflow tanks and they work very well.  I also know how to make a normal tank work well.  IMO the rotoflow is a great tank for a newer modeler that does not know about using fuel line barbs and a good retainer system for the fuel lines. ( i use twisted wire ) to keep the lines on.   I sue them on gas engins and one line is only a vent while i tee off the pickup line for a fuel fill.
gwweber is offline
Old 09-24-2012, 10:08 AM
  #60
Gray Beard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I still use barbs in some tanks if it's going in one of my big high dollar planes just to be on the safe side. Still, to date I have never had a fuel line fall off without them but the barbs make me feel better. Because my glow engines are YS I have gotten in the habit of taking a short, 1/8 or so piece of fuel line and sliding it over the top of the lines going to any of the nipples on the engine and inside and outside the tank lines. That really holds the lines very well and is very easy to do. Best of all, it doesn't cost anything.
We are just talking about fuel tanks and you don't need to be an engineer to assemble one. I have a lot of different tanks under the bench and just buy replacement bungs for when I need one. I do use more Du-Bros but I also use the Hays and Tettra tanks too. I think the most I have paid for one was about 12 bucks? 5 or 6 dollars is about the usual price for a tank. If I loose one in a crash I don't worry about it a lot! I haven't seen anyone mention adding a filter pick up inside the tanks. You can add a filter between the clunk and line or buy one of the new porous type of clunks to eliminate a filter for the engine.
Old 09-24-2012, 10:36 AM
  #61
gade600sdi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Put your filter in line after the clunk and the split off to the tee. Hangar 9 makes the best one I have seen the Pro Filter, it has very fine screen mesh and you can take it apart and clean it in seconds and it not expensive.
Old 09-24-2012, 11:24 AM
  #62
Gray Beard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There are a lot of good filters on the market, I like the Crap Traps.
Old 12-25-2012, 07:17 PM
  #63
STITCH48
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: chris923
Chris923
Glad to see some positive feed back on thisROTOFLOWtanks and everyone is entitled to thier own style of tank they see fit or have expreriance with. Been using your normal clunk tanks for years with very little troubles, but seeing theROTOFLOWon a fellow club member 50cc Extra I decided to switch to the newROTOFLOWtanks just so I don't to have to change tubing every season and been using them for about two years. Now looking to change fuel tubeing like Viton, but no one around here has used any yet.
Here are what this tanks are in:
1. The first one went into a GeeBee Senior Sportster with a two cylinder GF55ii engine.
2. 50cc MXS-R combo package from SDS with a two cylinder MLD 70cc engine.
3. 50cc 540 Edge from Top Dawg Aviation with a TMM 53 engine.
4. 100cc Hanger 9 Sukoi with a two cylinder 100Ccc 3W engine.
5. Rascal 110 with a Syssa 30cc engine (not flown yet).
6. 30cc Pilot RC Yak with a 38cc Mintor engine. (not flown yet).
Have to say that I personally have not had any problems with theROTOFLOWtanks, and have read some problems may exist and will keep a close watch on them.
Here's what I do know and have seen,this tanks don't like hard landing at all !!![/b]the brass tubing that the 45 degree clunk is supported on will bend near the rear of the rotating part of the clunk. This tubing is in need of an up-date, but I think they are cover by warranty.
This tanks are no heavier then any standard tank on the market and I use a two line system on all this tanks. The center pick-up tube goes to the carburetor and with a T-Fitting on that line you can both (gas engines only)fill and empty the tank. The upper nipple only is use to vent the tank and I coil the tubing before venting out to the bottom cowl area to help will dipping.
I think, but only guessing, that the third nipple below the upper vent, may be use for a pressurized tank system like that of a YS 140 so called fuel injected pump system. For gas engines this nipple is not needed, two line sustem works just find.
HAPPY HOLIDAYS TO ALL!!!!!!!!
STITCH48 is offline
Old 12-26-2012, 05:48 AM
  #64
jaka
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi!
But how about Uni-flow??
jaka is online now
Old 12-26-2012, 07:36 AM
  #65
sensei
sensei's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have been flying mostly gas airplanes for the last 15 years and have used only clear soda pop bottles as fuel tanks for the last I guess 8 years or so, anyway I can build a 32 oz. tank for a weight of about 2.5 ozs. and spend as little as 6 bucks to make myself. I don't use a filter on the end of my gas lines, just a barbed clunk, I filter all my fuel going in the tank and because I can see inside my tanks; this allows me to periodically monitor things.
Bob
sensei is offline
Old 12-28-2012, 11:25 AM
  #66
orthobird
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i have had several of these tanks.
advantage is connect fuel lines to outside, install, and you are ready to go.
never had had problems with tanks getting air in them or problems with engine performance.
have used them for nitro, gas engines.
i have even used two of these tanks in a 30% scale cap for the smoke oil.
disadvantage is:
cannot remove fuel from tanks unless you remove thru line that goes to carb
if you place your airplane to be standing on its spinner, and then lean top of plane back.
LOL
that's how i do it, and i draw fuel out thru vent line.
2nd disadvatage is cost.
orthobird is offline
Reply
Display Modes
