Pinning pined hinges?
TX
I have a VQ P40 that has been hinged at the factory and I want to pin the pinned hinges. What are some methods I might want to try? I have pinned ca hinges before but not the hard plastic hinges.
Banned
RE: Pinning pined hinges?
ORIGINAL: Wingspam
Of all my years in this hobby building and assembling aircraft- I have not once pinned my hinges! It's not neccesary and have not had any failures. Just make sure you soak the CA hinges, and it won't fail. My Nylon hinges I just epoxy in place making sure I epoxy both sides of the nylon hinge.
The number one reason from my observations why hinges fail is that they weren't properly installed.
Also, we never know when we might need to rebuild our plane, and removing anything that's pinned is a pain in the *****! I know! Plus we never know if we will be selling a plane to someone who will really take care of it, and will want to take it all apart and rebuild it the right way by removing all the components first, then recovering and reassembling the plane the correct way like I did to my Discontinued Great Planes Fokker DR1, and now rebuilding and modifying my League Models Neptune. Those hinges were pinned on the Neptune as well. %@#! Thank God for surgical clamps.
http://www.rcuniverse.com/forum/m_10038870/tm.htm
Pete
TX
I have never had a hinge fail that I have installed either, but these are factory installed and you never know who installed them. Adults or children..
Wing,
Probably wouldn't hurt to pin them with toothpicks. Obviously, you cut off most the point.
You could put a guide on the drill bit so as to not drill all the way through the wing tops.
Drill from the bottom and set the drill to just clear the hinge.
Charles
Charles
My Feedback: (-1)
Drill a hole from the bottom of the TE and LE edges but don't go through the top or you will see the pins. Clip off the tips of some round tooth picks. those holes should be a nice tight fit for the tooth picks. Use a drop of thick CA in the hole and push the tooth pick in so it goes through the hinge and anchors into the wood of the top of the edges.
I have seen a lot of hinges come loose for a number of reasons, the few minutes it takes to pin a hinge is well worth the trouble.
ORIGINAL: Gray Beard
Banned
Grey Beard
It is my opinion that hinges don't need to be pinned. Besides, I check all control surfaces before flight by tugging on them. So far I haven't got one loose. The ARF aircraft that already have the control surfaces glued, I check them and if one of them is questionable then I apply more CA.
The factory installed nylon hinges, I wouldn't mess with them unless they look or feel like they are seperating. Then I would carefully pull the control surfaces off and re-epoxy, or replace the original hinges all together and replace with Dubro Nylon Hinges. But if you insist on pinning them, then what everyone suggested so far is the way to go. We all have our different methods and they all seem to work. The toothpick method works well, and if you ever need to rebuild your plane then the GP Slot Machine will cut the toothpicks, but you would have to cut each side of the hinge to be able to pull the hinge out. Better than trying to dig those metal pins out later on if you had to.
Pete
ORIGINAL: Avaiojet
Anybody bother to read my Post?
Didn't I cover those areas?
A google search for drill guide: http://www.woodcraft.com/Product/200...ill-Guide.aspx
A google search for drill stop: http://www.instructables.com/id/Drill-Stop/
