engine starts backwards
my evolution .46 has a bad problem of starting backwards.has good compression and power and starts easily.would appreciate some helpfull ideas.
My Feedback: (7)
RE: engine starts backwards
A properly set up engine, sufficiently choked will do this regularly. Mine does. I start it with a back flip against compression. One flip starts are cool. <grin><grin></grin>
Yup. I first saw an experienced builder / flyer do that years ago. I was watching him prime the engine, after which he attached the glow starter. Then he held the prop backwards against compression for maybe 10 seconds, rotated a half turn in the direction of rotation, and then he grabbed the spinner. In what looked like a nonchalant backwards filp, he snapped the prop backwards with the spinner and the engine fired and started in the proper direction.
Took me about two tries to decide I could do that. I do roughly the same now with my Moki 1.80 - but I use a length of half inch plastic water pipe to push the big prop backwards against compression.
Use the feature to your advantage!
Dave Olson
Dave Olson
My Feedback: (-1)
Back flipping works, electric startes work but sometime just fattening up the engine a little works too. When I choke one of my engines they make a certain sound, a squishing sound that tells me they are ready to fire. If the engines have been run that day finger back snapping works very well, sometimes during the winter not so well. I always have an electric starter on hand for those days when nothing works.
