air up spring down retracts
Reply
Old 10-09-2011, 08:19 AM
billberry189
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default air up spring down retracts
I'm curious, what is an air up/spring down retract, how does it work and who makes them?
billberry189 is offline
Old 10-09-2011, 08:54 AM
dasintex
My Feedback: (10)
dasintex's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: air up spring down retracts
Others will chime in, basically, the retracts use compressed air to retract and hold the gear retracted in the 'up' position, and when the air is released the spring mechanism deploys or extends the gear and locks them in place in the 'down' position.
'Spring Air Products' manufactures and sells them http://www.retracts.com/
dasintex is offline
Old 10-09-2011, 09:48 AM
Gray Beard
My Feedback: (-1)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Love them!!Retracks are often a big problem. If you have a leak your gear isn't going to come down but with the spring that little problem is gone. They have to be mounted very well though, the recoil on the spring can break a weak mount in time.
Gray Beard is offline
Old 10-09-2011, 09:51 AM
Lnewqban
Lnewqban's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That is called a fail-safe mechanism.
Lnewqban is offline
Old 10-10-2011, 06:59 AM
LesUyeda
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
" and who makes them? "
Used to be an outfit called (surprisingly) "Spring Air":-)))))))))))))
Les
LesUyeda is offline
Old 10-11-2011, 10:17 PM
ho2zoo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think Robart is also now making some 'spring-down' retracts.
Like these: http://www.robart.com/products/sd-90...ready-wair-kit
ho2zoo is offline
Old 10-12-2011, 06:32 AM
ARUP
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm gonna give the 85 degree Robarts a try on my 1/6 Globe Swift currently under construction.
ARUP is offline
Old 10-12-2011, 10:57 AM
ira d
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had some Robart spring down gear but I ended up buying the parts and converting them to air up and down because the spring would not
always cause them to lock down.
ira d is offline
Old 10-12-2011, 05:31 PM
ARUP
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the info, Ira D. Anybody else have this problem?
ARUP is offline
Old 10-12-2011, 05:36 PM
BalsaBob
My Feedback: (24)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just be aware that you should not store the plane (or wing) on a flat surface with the gear retracted ...... the springs will compress and will not have the power/strength to lock the gear down.
Bob
BalsaBob is offline
Old 10-12-2011, 07:05 PM
JohnBuckner
JohnBuckner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
These are the genuine SpringAirs:
http://www.retracts.com/index.htm
Have not purchased anything from them for perhaps five years so do not know if they are still going.
I love my two tricycle sets of SpringAirs.
The Robart Spring down air up are not the same gear at all. The Robarts came out many many years after the SpringAirs and were marketed as their Economy Series whether or not they got it right is open to question it seems although I have never used them.
John
JohnBuckner is offline
Old 10-13-2011, 12:34 PM
Crash-RCU
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have both Spring Air and one set of the spring down Robarts and I like the Spring Airs better. The Spring Airs are a little bit more compact. The gear can be about a 1/4-1/2" shorter if need be on the Spring Airs than the Robarts
Crash-RCU is offline
Old 10-13-2011, 01:14 PM
pgilbert
My Feedback: (38)
pgilbert's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Does anyone know the difference between the 100, 200, 300, etc.? It's not very well spelled out on the web site.
pgilbert is offline
Old 10-13-2011, 04:45 PM
dhal22
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Light, medium and heavy duty ratings. And they are wonderful retracts. Very reliable and easy to use.
dhal22 is offline
Old 10-13-2011, 05:18 PM
Edwin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use spring-air mostly and like them. I've used a set of robart spring-air copies and they worked ok with no problem, but I think the spring-airs are stronger. I use the spring-air fill valve on all my planes, just because I think it works better than robarts and the B&D I used. Plus I have one common fill setup, not several. I've delt directly with the owner of spring-air and like him alot, he gives excellent customer service.
Edwin
Edwin is offline
Old 06-01-2018, 06:44 AM
kenair
My Feedback: (10)
kenair's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Question on air up - spring down - does the control valve dump all the air to let the gear down - on a go around can you retract the gear and then lower it again?
thanks - ken
kenair is offline
Old 06-02-2018, 04:53 AM
JohnBuckner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No the retract cycle does not dump all the air and multiple retract cycles are possible, the number of which is dependant upon the tightness and leak free security of your total system.
Am currently installing a NIB set of Springair's I have located in one of my new jets.
John
Old 06-03-2018, 07:57 AM
Pylonracr
Pylonracr's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The number of retract cycles is also dependent on the size of the on board air tank, assuming the leak free system as John stated.
Scott
Pylonracr is offline
Old 06-04-2018, 04:57 AM
Steve Collins
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
One drawback to the spring down retracts is that they will always be down when you are transporting the plane. Gets to be a nuisance at times when the wings have an extended gear strut.
In my long experience with pneumatic retracts, the concern over losing all the air in flight is overblown. A little leak testing of the components prior to installation goes a long way. Not saying you won't have air leaks; just that they are usually slow and rarely catastrophic.
Some of the Chinese made retract systems that are supplied with their ARFs are notoriously leaky. Use of components with a history of reliability is the secret of consistent success. Some of the best components are those from Robart, BVM, Ultra Precision, and Sierra Precision. There are a few other U.S. made retracts that are good as well.
Steve Collins is offline
