quick disconnect
My Feedback: (10)
quick disconnect
Building a Pawnee with ailerons and Flips. I'm looking for a way to quickly connect and disconnect them. Using Y-Harness now and its to confusing and too many wires pluging and unpluging all those wires in. Any help would be appreciated. Thanks Dick
My Feedback: (-1)
RE: quick disconnect
I run two short extensions from my RX and have one of them colored coded with paint to the right aileron wire and the other one is left blank. Just a daub of paint does the trick. My trainer has a Y and is left on the wing, it just plugs into the ch. #1 extension. The extension is glued to the top of the cabin on the fuse. Plug in/plug out.
I agree, I have used colored electrical tape as well as colored zip ties, It makes it easy. My Giant scale plane has connectors on the ailerons that will only fit the correct side. I have no idea where you can get them as they came with the plane that when I bought it used, but they do exist.
I was planning on a six servo wing for a sailplane and wanted only one plug to deal with. Would these plugs from radio shack work good? Do you think the connections would be sufficent?
http://www.radioshack.com/family/ind...goryId=2032286
skeeter
skeeter
CA
I am dealing with the same issue on a wing with flaps & ailerons on each side.
I have ordered some balancing plugs, male & female, with pigtails from Radical RC.
Each wing needs a +, -, and two signal wires. A 3S balance plug will work.
Then you only need to plug in two wires.
You could also use a 5S and have one plug.
I'll let you know how it turns out.
KW_Counter
KW_Counter
Hey Skeeter and Cotman,
I tried using the "Molex" plugs/connectors on my warbird. Have to hook up ailerons, flaps, gear and bombs...
The molex plugs did not come Gold Plated and after a couple of flights I was getting real bad "jitters" in the wing controls (flaps showed the worst). The plugs were from a good electronics store, I figured they would work great... Nope[]
I switched back to gold-plated aileron extensions and added color markings on each lead - no more problems and it is not that big a deal to plug in 4 instead of just one.
I spoke with another scale guy who said that the "regular" (not gold) electronics connectors either get corosion fast or do not hold up well to the vibrations. Even with a clip to secure the plug, they developed the glitching..
So, just from my experience - you can't go wrong with gold aileron extensions and I'm not trying the Molex experiment again.
Tom
Tom
OK
I too use colored coded striping tape to each lead. Red to red alerons, blue to blue retract, white to white flaps. As to flaps and alerons, using a Y is the simplest because it really does not matter which servo lead it is connected to provided you mount the servos arms opposing each other or are facing each other. The same is true to flaps, the arms should be on the same side of the servo when mounted. With the retracts though, there is only one lead and just insure it is plugged into the right receiver connection. Then there is the situation where you have alerons on separate channels. Then you need to color code the leads to the receive to insure they are in the correct connection on the receiver. Other wise you may have to reverse the servos to insure left is left and right is right. Then there is always the fact that I don't understand the quesstion and this is TMI.
To bad you had the problems with those plugs. I hoping for a good experience with them. Guess i'll just stick with the normal way till something better and proven comes along.
skeeter
skeeter
Non-gold plated connectors are usually only good for a few plug/unplug cycles.
I use a digital label maker on my leads, but the other option I would consider, Hanson hobbies carries tools and components to make your own servo leads that are of higher quality than the components I've bought from LHS.
In addition to the 1x3 housings typically used on servos, they have a full range up to 1x10 or 2x5 that accept the same gold plated pins. The downside to that would be sleeves are only available for the 1x3.
They do also have red and blue sevro connector housings in addition to black.
Personally, just using a label maker works best for me.
I don't know how available these are in the USA but Multiplex plugs have six connctors so you can use the to connect multiple servo's with the least amount of plugs.
http://www.modelshopleeds.co.uk/cata...oducts_id=7822
Jim.
Jim.
The Multiplex connectors are available in the US and they would foot the bill for your connections. I have them in my jet which has twin booms....so coming through each wing to be connected is 1 aileron, 1 flap, 1 elevator and 1 rudder. By using the multiplex 6 pin connector I have the ailerons and flap on one and the rudder and elevator on the other. 2 plugs and it's done. Just so there is no confusion of which plugs to which, 1 pair uses the positive side of the plug, and the other pair uses the negative side.
