servoes
NY
servoes
I have a new bird that uses 2 servoes per. wing panel i am using HS 5625 servoes. I have used 2 servoes together before & never used a match box but thay were analog servoes what do you think ?
RE: servoes
a match box allows you to balance the work load of the servos....much like paralleling generators......keeps one from working too hard while the other isn't doing much or at a set throw keeps one from pushing against the other
My Feedback: (158)
RE: servoes
I would match them with a match box or a programmer,,
I actually have the 5625s' on my 33$ extra for ailerons,, and I was surprised how off "centered" from each other they were, with the inexpensive hp-21 programmer they run almost perfectly together. No match box needed
