Alcohol question
TX
RE: Alcohol question
well the reason I ask is ive got a book by Harry Higley and its called all about ENGINES and it recomends to use (Solvent Alcohol) but im sure its a little dated as the copyright is listed as 1992.
GA
Denatured and rubbing alcohol are different things...
http://www.ehow.com/facts_4927521_al...g-alcohol.html
Rubbing alcohol will be available at the drug store or the grocery store..
denatured is usually only at the hardware stores.
TX
I just went to lowes and picked up a 32oz can of the denatured alcohol, it was 7.88 with tax out the door. Ive got a os .40 fourstroke engine I want to try it on, inside and out. Its gonna be the gueinny pig before I try it on my saito 91
My Feedback: (-1)
I use a lot of alcohol, even sometimes for cleaning. Kidding aside, alcohol isn't very good for cleaning off burnt on Castor oil. I do use it to clean the inside of the engine after a rebuild before assembling. Just make sure to oil up the bearings real good after an alcohol flush.
My Feedback: (-1)
ORIGINAL: DavidAgar
Some of the alcohol's have alot of water in them, so once you clean the engine, make sure you give it a good oiling. Good Luck, Dave
