Reload this Page >
Bi-Plane with-out cabanas
Old 02-12-2012, 06:15 AM
James c harrell
My Feedback: (18)
James c harrell's Avatar
Default Bi-Plane with-out cabanas
I picked up a plane at a swap-meet the other day and have a question. It is a bipe and has no cabanas on the outer wing. The plane appears to be complete and I was wondering if any-one knows of one that was designed without them. I need to know where to balance it,and short of doing the calculations which I did best I know how, it would be nice to know what it is.
ID:	1726031   Click image for larger version
Old 02-12-2012, 06:28 AM
Live Wire
Live Wire's Avatar
Default RE: Bi-Plane with-out cabanas
Can you take a picture from the side a person can get a better idea what it is.
Larry K
Old 02-12-2012, 06:41 AM
TFF
Those struts are called interplane struts. it is ok for that kind of biplane. Cabane struts are the ones next to the cockpit. I was hopping to see a plane without those.
Old 02-12-2012, 07:23 AM
JollyPopper
JollyPopper's Avatar
I have a Sig Liberty Sport that I built from a kit a long time ago. The instructions say that the plane was tested and can be flown successfully without N struts (interplane struts). They look nice but are not absolutely necessary. There are no doubt others as well. Take a couple pictures from the side of your airplane and maybe somebody can identify it.
Old 02-12-2012, 09:28 AM
James c harrell
My Feedback: (18)
I think it has been flown but not for sure. It has a .36 engine. Nice little plane and what I like the most is how easy it is to take down and put together.
Old 02-12-2012, 09:33 AM
exeter_acres
exeter_acres's Avatar
i've never seen an airplane with cabanas.....
Old 02-12-2012, 09:49 AM
Lnewqban
Lnewqban's Avatar
If your plane is not this one, it is pretty close:
http://manuals.hobbico.com/gpm/sport...-40-manual.pdf
Old 02-12-2012, 10:22 AM
James c harrell
My Feedback: (18)
I thought it was a sportster too but it has no sweep to the top wing. Both are straight.
Old 02-12-2012, 10:35 AM
TFF
Kind of looks like a Chuck Cunningham (?) design.
Old 02-12-2012, 12:24 PM
TLH101
My Feedback: (90)
TLH101's Avatar
It's a Tiger Bipe .40 ARF
http://www.rcpro.no/main.aspx?page=a...no=CA40.TT4557
manual: http://www.rctube.eu/download/rc/ins...er_bipe_40.pdf
Old 02-12-2012, 12:25 PM
Lnewqban
Lnewqban's Avatar
If a Tiger, here is the manual then:
Copied from a published article of Andy Lennon:
AERODYNAMIC CENTER (AC) LOCATION
For a biplane, locating this center is not difficult. First, the AC of each wing lies farther forward on a biplane at 23 percent of the chord rather than the 25 percent of a monoplane's.
For an orthogonal combination, the AC is on the vertical line joining the 23 percent of chord of upper and lower wings.
For staggered combination of equal area, span chord and aspect ratio, the situation is different. For negative stagger, the AC is located midway between the wings on the line joining the 23 percent of chord points. For positive stagger, it is at 57 percent of the distance from lower chord to upper chord measured on the line joining the 23 percent of chord points.
Where the wing's areas are unequal, the vertical location along the line joining the 23 percent of chord (MAC for tapered wings) is fixed by the following formula:
X/Gap = Upper wing area X P / Upper wing area X P + Lower wing area
where:
X=distance of the mean chord from the lower chord, and P=a weighting factor of 1 for negative stagger and 1.35 for positive stagger.
See attached schematic.
For the MAC of each wing, you can use the on-line calculator listed in the Aerodynamics forum.
This is another article explaining how to determine CG:
http://www.modelairplanenews.com/blo...cing-biplanes/
Old 02-12-2012, 02:22 PM
James c harrell
My Feedback: (18)
Thanks for the help guys! Always nice to know what you got. Turns out the CG was dead on. Just need to test top her. I will do that Wednesday at our weekly meeting of "The Liars and Fliers" at my club. Will post the on-board video Wednesday afternoon.
Old 02-12-2012, 03:42 PM
fred985
isnt canabas illegal,,? or this may be for medical use ? besides isnt this supossed to be a family type of activity ?
Old 02-12-2012, 03:46 PM
fred985
from the pics the cabanes are terribley out of line. i think you are refering to the N struts. they brase the wings and probably should be installed.
Old 02-12-2012, 04:15 PM
James c harrell
My Feedback: (18)
No struts in the plans Fred. Doesn't need them evidentally!
Old 02-13-2012, 06:17 AM
Rodney
I've found that the inter plane struts come in handy if doing any violent aerobatics. Should the cabanes be slightly weak or the top wing firmly attached to them, you can find the upper and lower wing tips on one side or the other touching in such things as snap rolls etc. The inter plane struts prevent this from happening.
Old 02-13-2012, 09:38 AM
cstevenpeterson
My Feedback: (21)
I have a newly assembled Tiger Bipe 40 hanging in my basement (been there a while). I have a TT Pro .36 in it. Hope to fly it this Spring. Neet little bi plane, but I do not believe it will be a "barn burner" - just a little knock around Sunday flyer. Good luck with yours.'
Steve
