Cleaner
Cleaner
I am looking for a cleaner that wont be too hard on the covering on my planes..I understand that anything with ammonia is not very good for them..I have been using Windex but that has amonia..I heard about Glass Plus here on line but I havent been able to find any so far.. I did find some called Green Works..It has Ethanol in it..Does anybody know anything about it? Is ethanol okay or is it hard on covering too? I suspect ethanol might be even worse because it is sort of like Alcohol but maybe if its weak enough...Thanks for any thoughts on this
RE: Cleaner
Are you looking for a cleaner after you fly? I use Simple Green. A gallon is about 10 bucks and makes a lifetime worth when diluted. I keep a small spray bottle full in my field box.
Moderator
RE: Cleaner
Whatever spray you use if you'll buy a microfiber rag to wipe with you'll get your planes cleaner with much less effort. I do an initial wipe down with no spray at all and the microfiber cloth gets the covering squeaky clean by itself. I'll hit it with some of the orange oil spray cleaner to make sure the seams are clear of residue before putting the planes in storage.
RE: Cleaner
Thanks Guys...I like the Idea of using microfiber rags because if I can wash them out it will save on the paper towels that I use now..My covering gradually comes loose around the edges in places..I dont know if it's the amonia or not..It didnt matter much before because I always built all my planes and when I cover I lap by about 1/2 " but I bought a couple of ARF's and it seems like they only lap there covering by about 1/16" , maybe 1/8" Tops so when it starts to come loose you better get on it pretty quick or you are in trouble...I will try the Dawn too..Thanks again
NY
RE: Cleaner
I use rubbing alcohol and paper towels - no problem with covering. I buy two qts at Sam's club for $3. I just put a spray top on the bottle. Cuts oil very well.
