sealing gaps
Reply
Old 03-15-2012, 03:55 PM
tazzzz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default sealing gaps
Whats the best way to seal control surface gaps i.e. ailerons,rudder etc., Ive heard there was a plastic tape or something you can use,,,,if so where do I get it?
ThanksTAZZZZ
tazzzz is offline
Old 03-15-2012, 04:00 PM
1320Fastback
1320Fastback's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: sealing gaps
It's called BlenDerm Medical Tape.
It is probably going to be a online buy but might be available in pharmacies.
If your plane is covered though then covering of the same color or clear covering is best.
Either way seal the gaps. It make a huge difference in the performance of the plane.
1320Fastback is offline
Old 03-15-2012, 04:08 PM
SeamusG
SeamusG's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Best? What's the current covering? Is it a simple color on both fixed and moveable surfaces? Is it complex with many trim pieces thru the gap? Is it electric, gas or glow? So many questions. Enquiring minds need to know.
SeamusG is offline
Old 03-15-2012, 04:20 PM
tazzzz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Its an ARF with glow,,and orocover
tazzzz is offline
Old 03-15-2012, 05:22 PM
invertmast
invertmast's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: 1320Fastback
I would love to see some hard evidence of this! I've had many speed planes, and anything under 120mph sealing the gaps did nothing but take time! Really, i never noticed more than 1 or 2 mph between speeds of 120-150mph. Once the speeds started reaching 160+ it made a difference...
The BEST way I have ever made a noticeable difference, was Ensuring a TIGHT hinge gap between the control surface and the wing/tail. That makes more of a difference than sealing the gaps.
invertmast is offline
Old 03-15-2012, 05:29 PM
bradharvy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dubro hinge tape. I used it to stop the "whistling" noise in my stick. Clear so you don't even see it. Unless you know it's there! It helped my "whistling" noise..
bradharvy is offline
Old 03-15-2012, 06:04 PM
Jetdesign
Jetdesign's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can use clear covering, but tough to keep anything permanently sticking if you've already slimed the plane.
I can't say much about the performance gain - I have yet to fly a plane w/o hinges sealed and then with them sealed, however I did just seal the gaps on my contest plane so I should know by this weekend
Aerodynamically speaking, it's easy to see how the plane would fly/respond better with the gaps sealed. It should be more consistent, with more control surface authority due to less high pressure spillage through the gap. Similar to the 'winglets' you see on the tips of commercial airplanes - they're all doing it now, 'cause the spillage of the high pressure air under the wing around the wing tip decreases lift/efficiency.
Jetdesign is offline
Old 03-15-2012, 06:53 PM
Rubbernecker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: invertmast
Gotta agree with you on this one. Been flying 38 years and have NEVER sealed a hinge gap. I make them nice and snug when I build it. Most probably couldn't tell the difference between one sealed and one that was tightly fit. Also have a racer in the 100+ range and never noticed any issues with it. To each their own.
John
Rubbernecker is offline
Old 03-15-2012, 08:24 PM
1320Fastback
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry I did mean aerodynamic performance like nice straight loops and consistent repeatable pattern maneuvers.
Old 03-15-2012, 08:31 PM
Oly
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sealing the hinge gaps does make a difference you can feel. If it didn't, why not make the hinge gap as wide as you want, instead of trying to make it as small as possible? A small hinge gap that is sealed will not only improve performance, but helps prevent flutter (notice I said helps). I use the covering I covered the plane with. I've even used multiple overlapping strips to blend with the different colored trim schemes. This is purely aesthetic, as I don't like the "bubbles" that clear tapes produce.
I highly recommend sealing hinge gaps.
Oly
Oly is offline
Old 03-15-2012, 09:55 PM
Mk23socom
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I say why hing anything!?. Use hardwood dowels and blend the control surface to the wing or stabilizer.. problem solved!.. ALTHOUGH, I don't think it will fly too well.. HEY JIM, how ya doing!?
Mk23socom is offline
Old 03-16-2012, 12:56 AM
epr3
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
when I was racing , we use a clear tape from 3M that was clear and very flexible. Sealing the gaps ( even if they are tight) make a big difference !
epr3 is offline
Reply
Display Modes
