Can I use these servos in a 50cc class Yak?
TN
I have a new to me 50 cc class Yak 54 ARF which is no longer made. Not sure of the brand of the plane. The wings of the plane has 2 servo slots in each wing, 1 servo slot in each half of the horizontal stab. and a place for 2 servos for the rudder, ganged together. I want to use 5645 digital servos in this plane. The instructions indicate no servo size. the 5645 is rated @ 160 oz torque at 6 volts. If I install 2 5645's in each wing will that give me a total of 320 oz per wing? If so that ought to be more than enough for imac or 3d style stuff. Right? and 1 5645 in each horizontal stab should be more than enough right?
My Feedback: (7)
RE: Can I use these servos in a 50cc class Yak?
I can't imagine why not.. I am not into the 3D scene at all but I probably would not hesitate to use 5645s in pairs on the surfaces like that..I have some experience with the 5645s and they have, so far, proven to me to be a sweetie if they are not abused... I am absolutely SURE that someone will say otherwise and I am sure they will have good reason to..
My Feedback: (-1)
There is a giant scale and giant scale 3-D forum, if you post a photo of your plane there will probably be someone there that knows who made your plane and knows exactly what it requires. OK, not exactly but they will have a better idea then the general public. A 160 inch pound servo sounds like a big servo to most people, myself included but I run bigger then that in pattern planes. Servo speed and gear trains also count for a lot in making a choice. Try posting with a photo in one of those forums and see what people think. I'm sure you will end up with a lot of knowledge of your plane too.
