If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 8 of 8
  1. #1
    Join Date
    Jan 2012
    grand prairie, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Goldberg Cub Windows and cowling
    I just picked up two Carl Goldberg AnniversaryPiper Cubs at a swap meet yesterday and I need to replace the plastic windows.Will the ones made by Great Planes fit? Ialso need to replace the cowling.
  2. #2
    DavidAgar's Avatar
    Join Date
    Dec 2001
    Battle Ground, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Goldberg Cub Windows and cowling
    Carl Goldberg was bought by Great Planes and they are still seeling parts for the Golberg Cub.....Good Luck, Dave
    http://www.carlgoldbergproducts.com/.../gpma0963.html
    If the screw ain\'t loose then things ain\'t normal.
    Dave Agar
    AMA#97144
  3. #3
    oskartek's Avatar
    Join Date
    Nov 2009
    West Jordan, Ut
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The parts are available but not cheap,
    Hope this helps.
    Happy flyin'  Oscar
    A man that hates kids and dogs cant be all bad. But then, Ive met some dogs that I liked.
  4. #4
    Join Date
    Jan 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Got any clear Monokote? That'll work for the side windows. 'Flat wrap' the windshield by sourcing the plastic from a large soda bottle and make little balsa blocks to fit inside the 'stubs where the wing joins the fuse. Cheap enough!
  5. #5
    Join Date
    Sep 2006
    White Oak, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I've had very good luck making the side windows for cabin planes using a simple gravity forming method. It requires making both a male and female die from plywood the thickness of cabin sides. The male die is about 1/16 - 3/32 inch smaller than the female. A set of dies will work for either side of the cabin... just flip them.
    I use a discarded crock put oven but the kitchen oven will work fine. Place a piece of wax paper on the oven bottom or a cookie sheet if using the kitchen oven. On it goes lays the male die. A piece of .015 polyethylene is placed on top of the die with it being cut about a half inch over size all around. The female die is placed on top of these aligning the gap equal around. On top of all this a piece of plywood and finally a weight above all.
    Cover the oven and heat until the weight drives the female die down over the male to the oven bottom. I use the low heat setting on the crock pot and it takes from 15-20 minutes. Let cool and remove. Trim the inside shoulders about 1/4 inch for gluing.
    The gravity process is much simpler than vacuum forming and uses far less material as a full piece of plastic is not needed.
    http://www.rcuniverse.com/forum/m_92...tm.htm#9233344
  6. #6
    Join Date
    Apr 2003
    Hemderson, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I just built one for a friend last summer. I made all new windows myself but then found out the owner bought a new set, I think he got them through Tower? Reason I'm not sure is he also bought a really nice cowl and landing gear from Fiberglass Specialties and he may have gotten the Windows there?
    Drinking and driving are illegal, why do bars have parking lots
    Daisy Air Guns, keeping kids off your lawn for 100 years
  7. #7
    Join Date
    Jan 2008
    Arlington, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I thought you was gonna leave that mustang cawl on it, I thought it looked kinda cool but differant.
    Cub brotherhood #113
  8. #8
    Join Date
    May 2010
    Deer Lodge, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I didn't want to pay the high dollars they ask for the windscreen. So I just made a block of wood that looks like the wing ends inside the cabin, and then used a sheet of paper to make the windscreen. Then I got a sheet of clear plastic at the lhs for a couple of bucks, and whala! Looks better then the one you buy, and I saved money to buy something else I wanted!
    Pat
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1754272   Click image for larger version.
ID:	1754273   Click image for larger version.
ID:	1754274   Click image for larger version.
ID:	1754275   Click image for larger version.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
