If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 1 of 2 12 LastLast
Results 1 to 25 of 26
  1. #1
    Join Date
    May 2003
    FramlinghamSuffolk, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    HELP PLEASE! Suggestions on hand-starting petrol engines
    Dear All,
    Thanks for reading!
    My situation is that at the moment, I'm bench running a petrol engine before I put it in my 5th scale Yellow Aircraft Spitfire. It's replacing the glow engine that has made it crash twice!
    It's a Meiss 45cc inline twin petrol (http://www.meiss-motoren.de/Reihenmotore/45_R/45_r.html).
    At the moment, on the test bench it has a small plastic spinner on it so that I can start it with my electric starter, but I won't be able to use the electric starter on it once it's in the airframe, so I've got to get it to the point where it will start easily by hand. The reason for this is that once in the plane, it will have a large spinner on it, too big for the electric starter.
    At the moment it starts easily with the electric starter, but the best I've had by hand so far is a fire and a splutter that lasted about a second. My questions are:
    1. Do you have any tips for getting large petrol engines to start by hand? (This is my first petrol)
    2. Are there any solutions in existence for electric starting engines with large spinners? (It's a 5 5/8 inch machined aluminium spinner, that I'd rather not wear the paint off!)
    Many thanks in advance!
    Jason.
    "If I had all the money I've spent on radio-controlled models, I'd spend it on radio-controlled models."
  2. #2
    JohnBuckner's Avatar
    Join Date
    Dec 2001
    Kingman, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: HELP PLEASE! Suggestions on hand-starting petrol engines
    Sorry no suggestions on tuning/operating your engine. It would be rare indeed here in my country but why not a large cone?
    I have a home made one that slips over a standard starter cone and uses a large silicon cone.
    The one on my geared starter uses a three inch hole saw and a store bought silicon cone insert.
    John
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1764215   Click image for larger version.
ID:	1764216   Click image for larger version.
ID:	1764217   Click image for larger version.
    \"Keep your controllines tight\"
  3. #3
    The Ghost's Avatar
    Join Date
    Mar 2004
    UlladullaNSW, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: jasona
    Dear All,
    Thanks for reading!
    Jason.
    It's all a matter of getting it tuned correctly. Not being able to see the engine and not much info here it sounds like it is not tuned correctly. Once the engine is tuned correctly it will hand start easy. It may be a bit lean on idle and you may have the idle speed too low.
    This is a Zenoah G-62 hamd start.
    [youtube]http://www.youtube.com/watch?v=17aNAXFDeTQ&feature=g-upl[/youtube]
    Cheers
    Remember, Always look after the ORGANIC part of the model
  4. #4
    Join Date
    Sep 2002
    Orlando, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    tuned correctly is very true, when i hand start my gas engines, i turn on choke, flip till it barks, make sure throttle is at idle, turn off choke and flip usally 1-3 flips and its running
    I once had a drinking problem.....I divorced it, now shes someone else\'\'s problem
    waco brotherhood # 140 BUSA brotherhood #88
    currently flying proctor albatross x2, busa 1/3 nieuport 28, reeves 1/3 camel, 1/3 airco DH1a
    on building board 1/4 beech staggerwing, repairs underway 1/3 carf gee bee r2
  5. #5
    Join Date
    Apr 2003
    Hemderson, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Most the time I would just tell you to go to the gas engine forum and ask around, I have never heard of a Meiss engine. I did something else I tell a lot of people to do, try doing a search and see what you can find out.
    I wanted to see this engine so I did a search myself and located a thread with a bit of talk about the Meiss engine, found it in the war bird forum posted in 2010. Seems it is/was a German made engine. Some of them are Boxers too. Some of them used Zinoah parts. I didn't find a lot of information about them but I did find the email address for what looks like the manufacture. info@meissmotoren.de I didn't dig too far and I did find some more threads. I think I would just use the big cone like John showed you. If I had one on my bench I'm sure getting it to hand start would be easy but there are some simple things I couldn't see in the photos like if the chokes butterflys have a hole in them or if they are like my G-62 and don't have a hole or close up all the way to choke well and need a finger over them to choke well?
    Do a search and try to talk to someone that knows something about the engine and uses one so you can get better information.
    Drinking and driving are illegal, why do bars have parking lots
    Daisy Air Guns, keeping kids off your lawn for 100 years
  6. #6
    Join Date
    Feb 2002
    Keller, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    jasona
    You haven't described what kind of ignition you have, I'm assuming it is magneto. If so, you can't effectively use the same technique as for a glow engine. A glow engine has the ignition constantly "on" so long as the plug is glowing, so starting the prop up against compression works well. With magneto ignition, the magnets pass across the coil to generate the spark, and need to pass at some speed to do this. Thus, need to begin the prop flip well before the magnets pass the coil so that when they get there, they are already at speed. What works for me is to position the prop so that it is at the 9:00 position when the magnets pass the coil, and I begin the prop at the 12:00 position, giving about 90 degrees of rotation to build the prop speed before ignition.
    You may prefer a different position for the prop, but it is important to get it started in rotation before the magnets pass the coil.
    Of course, priming/choking is the same for magneto engines as for electronic ignition.
    Good luck.
    After seeing pics of the engine, Ican't see where a mag would fit. I also don't see any electronic ignition, but that is easier hidden than a magneto. So, never mind!
    Sometimes, things are exactly as they appear to be.
  7. #7
    Join Date
    May 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Dear everyone above,
    Thanks so much for replying! The kindness inherent in taking the time to shoot a video, take pictures and then upload them is huge! Thank you very much!
    The engine is much improved: It's set up well now and running and starting very nicely, but only with the electric starter. It's becoming increasingly obvious that it won’t start by hand.
    The Ghost: Brilliant! Wish mine would do that!
    Gray Beard: Very kind, but I included a link to the engine in my first post and am in direct contact with Meiss Motors. Responses come in somewhat broken English though as he’s German!
    RCVFR: It’s electronic ignition, running off a separate battery.
    John Buckner: I’m inspired! Absolutely inspired and enthused, particularly as you have the identical starter to me! You made up an adapter that fits over the original! Brilliant! Not the geared one, but the first three pictures. Fantastic.
    A large cone is definitely the way I’m going to need to go and what you made is just what I need. It’s outside of my resources to machine up one like you made, but I wonder if I could bribe you enough to make one for me? What would it take? I mean what if I offered silly money for you to make one exactly the same as you have? $100? $200?
  8. #8
    Join Date
    Dec 2001
    Kingman, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Jason, Yup you really need a large cone setup. The slipover large cone was made for me by a friend as I am no machinists. But there is no need to resort to "silly money" just yet though.
    If you look at the geared starter close you may recognize the large 3 inch cone cup is actually a common three inch hole saw. The only tedious part is grinding the teeth off. The mandrel parts are just removed and it is bolted on the motors shaft just like the normal small cone cup.
    The silicon insert you will have to obtain and I cannot tell you who has them since I did some horse trading for that one. I beleve they may be had from Sullivan or Miller and the three inch fits into the three inch hole saw perfectly.
    John[8D]
  9. #9
    Join Date
    May 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi John,
    Great to hear from you! As regards the insert, do you mean this kind of thing?
    http://www3.towerhobbies.com/cgi-bin...P?I=LXUSG3&P=8
  10. #10
    Join Date
    May 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yay! Problem solved!
    It turns out that a long-standing supplier of mine does this as standard, I won't have to fabricate anything and it's not silly money, either! Look at this, plus the optional larger cone and insert:
    http://www.justengines.co.uk/acatalo...15.html#aJENST
    Perfect.
    It came up when I was searching on "silicon rubber insert" to go in the hole saw!
    Thanks again for all the very kind replies though.
  11. #11
    Join Date
    Dec 2001
    Kingman, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yes they list the outside diameter as 2.85 inchs (also a metric equivilent) and what you must to is go to a tool shop and find the size hole saw that will be close to this. Sorry I cannot help with the metric sizes.
    John
  12. #12
    Join Date
    May 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    It's OK, I'm sorted John: See last post above. Very handy.
  13. #13
    Join Date
    Dec 2001
    Kingman, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Fantastic Jason and that will certainly do the job And please do post some pictures of your Spitfire if ya' can when your done right here on this thread. Would love to see it and pictures of your flying sites.
    Always loved to see model sites around the world via this magic we are communicating on
    John
  14. #14
    Join Date
    May 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Great, thanks John, will do. It's for this:
ID:	1775594   Click image for larger version.
ID:	1775595   Click image for larger version.
ID:	1775596   Click image for larger version.
  15. #15
    Join Date
    May 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    It's the Yellow Aircraft 5th scale Spitfire: Crashed on its first maiden because of the bloody engine. Crashed on its second maiden because of the bloody engine, hence my now switching to the petrol engine I need this starter for. Hoping for 3rd time's the charm or "3rd time lucky" as we say here in England!
  16. #16
    carrellh's Avatar
    Join Date
    Mar 2003
    Garland, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Nice plane Jason. I hope the gas engine solves the relibility issue.
    - Carrell
  17. #17
    Join Date
    May 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: carrellh
    Thank you! Me too!
    The pictures are after I finished repairing it the first time and just before the second maiden. Fortunately, the damage was relatively light when it crashed the second time. Just some minor repairs to do now and to fit the new engine.
  18. #18
    Join Date
    Dec 2001
    Kingman, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    A lovely ship Jason, appears to be a model of one of the later marks. Best of luck on the maiden and do post any pics or vidio's you may get.
    John[8D]
  19. #19
    Join Date
    May 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks John! Yes, it's a MKIV, done in the markings of Ginger Lacey, as my Dad knew him in real life! Airbrushed all the camouflage myself: My first ever time with an airbrush!
  20. #20
    Join Date
    Oct 2006
    powell, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just out of curiosity what kind of glow engine was in it and what kind of problems were you having with it?
    Club Saito member # 689/topflite AT6/KMP B25 /H9 B25 /sterling PT-17/Andrews aeromaster/H9 p-51/BUSA eindecker/SE5A/J3 Cubs
  21. #21
    Join Date
    May 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    It was a Super Tigre 60cc inline twin glow (only one carb for the two cylinders though). It kept going on to one cylinder.
    On the first maiden, it went on to one cylinder and then no cylinders! Big crash, lots of debris.
    On the second maiden, despite having fitted onboard glow to both cylinders and other mods, it went on to one cylinder straight after take-off (tried to upload a video but it won't let me)
    I think it doesn't like being mounted inverted: It seemed fine when we were running it upright when we were running it in on the bench. I'll be putting it on eBay shortly. I'm now switching to petrol with nice, safe, reliable spark plugs that fire every single stroke!
    So how do I attach a video to this?
  22. #22
    Join Date
    Dec 2010
    AugustaGA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    on my 56 cc i turn on the radio open the throttle close the choke flip it about 15 times on first cold start , pull back throttle turn on ignition flip prop engine will hit then stop open choke flip once or twice then it should run ,, after intial cold start just close choke till it burps then open choke and should start easy hope this helps , they start easy with the electronic ignitions
  23. #23
    xcz5785's Avatar
    Join Date
    Aug 2008
    Palatine, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have a DLE with electronic ignition. Its easy. Just turn on the ignition, choke, flip till it it pops, turn off the choke, flip till it turns over which is just about two flips. If you have a magneto you will need a starter, more reason to get rid of the plastic spinner.
  24. #24
    Join Date
    Apr 2006
    st cloud, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    HAND START WITH A HOCKEY GLOVE .HAVE USED ONE FOR YEARS!
  25. #25
    Join Date
    Dec 2011
    shreveport, LA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Whether magneto or ei
    You have to set propeller on shaft in such a fashion
    That one blade is at 1 or 2 or 3 o'clock position
    Then
    When you go to flip
    Either sensor on magneto or ei must be prior to its sensor position
    When you flip it and prop begins swing counterclockwise
    This is why it starts with electric starter
    Since this obviously wil cause spark on second go around
    Which you do not get hand flip.
    Of course, always use a glove.
    I have 6 gas engines
    All start easily
    I have never used electric starter on those engines.
    If you learn to flip it
    And also how to use choke
    Then this becomes very easy!
    Let me know how it goes
    AMA # 982277
    Carden Extra 300 Pro, almost done building it (DA 200 with KS cans)
    Carden Extra 300 Pro, in the works (DA 150 with KS 1090 tuned pipes)
    Dalton Extra 300 SP, finished and crashed, RIP
    Dalton Extra 300 ML, DA 200
    Dalton Yak 54, DA 200
    Great Planes Matt Chapman Eagle Cap DA 120
    Top Flite Gold Edition Giant P51 DA 85 (in the making!!)
    Extreme Flight YAK 54 91" DA 70
    Extreme Flight Extra 300 91" DA 85
    Extreme FLight Extra 300 78" DA35
    JETI is the only way!!!!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
