top flite taurus canopy
My Feedback: (10)
hi
i am looking for a t-f taurus from the 1960 canopy where would i start looking i am invoild with a kit cutter that is redeigning the kit or updateing it for my next winter build maybe even a club build to see who can build the best one but i need a canopy ,thanks
RE: top flite taurus canopy
Search for somebody here called Taurusflyer... from the Netherlands if I remember... Taurus mad... as you'll discover.
Normally hangs out in the classic pattern section.
He'll know for sure.
Contact Jeff at Home and Hobby Solutions. He sells a Taurus replica kit. I used some of his parts to rebuild my old crashed Taurus. He may have the canopy you need. http://www.classicrchobby.com/
My Feedback: (24)
AZ
I built a Taurus from scratch last year. The canopy I matched to the plans I obtained from SIG Manufacturing. They have several size canopies available. Meadure what you need from the plans, get the canopy from SIG and cut off the trim and you are ready to go. Taurus Flyer is a great resoource for technical info while building. I built mine to resemble the original Kazmirski Taurus and used an OS 50SX for power.
Good luck, and let us know how you end up.
Gerry
All,
parkflyerplastics.com has Taurus, Orion & Tauri canopies. The mold was cast from an original canopy from a Taurus kit. BTW - Top Flite used the same canopy for all 3 models.
FB
FB
ORIGINAL: David Bathe
rye,
I build one and I balance it to the plans a lot of weight in the nose ,she saps in the turns one guy said I should make the nose longer to get the weight down and balance out the long tail . Thanks
The Taurus is famous because of the characteristic dimensions, short nose and long tail moment, so you "should" build a new one!(LOL)
How is the Taurus flying?
TF
My Feedback: (10)
hi tf
well we flew it two times and the same thing it saps and had a lot of weight in the nose i bearly got it to land and took it home and going to do the same thing cut off the nose and make it longer and maybe take off the covering and cut hose in the tail feathers and ailrons to and cut lighting hoses it the body it sound like a lot but what do i have to lose i wouldnt filer her like this no more so if i dont do this she becomes a wall queen anyway i am building two C-G tiger 60 sizes and put a lot of lighting holes where i could this plane has a long tail too got one done for my son and getting ready to cover mine ,i going to save the taurus for the winter time ,good luck rye
