Li-ion battery charger
TX
Hello all, so i purchased a large heli the other day and it has a double pack 7.4 2200 mAh battery pack in it. Im not looking to fly with it but I do want to know how to properly charge it and test it, can anyone help me out here? There are two packs bundled together so im guessing total volts would be 14.8?
RE: Li-ion battery charger
Andy, the second response knows what he's talking about...as far as your battery....don't assume anything. Battery cells wired in parallel will have the same Volts but the available current will additive. While cells wired in series will have twice the voltage but the available current will stay the same. Twice the voltage is not good. You'll let the magic smoke out at twice the voltage and it won't ever work again. once the smoke gets out...you can't pour in more smoke....
Moderator
Scott, if we're still going to get together Saturday I'll bring my Triton EQ. It can charge those batteries, and if you want, I can take them and do a cycle test.
TX
Sounds good paul, I will bring them with me on sat. Thanks guys, this battery set up is new to me as I have never seen it before so I just want to know what Im doing before I screw something up.
