Radio Expert, Help!
FL
Radio Expert, Help!
I have a Hanger9 Corsair that was built by someone else that is set up on a Futaba 9C radio (converted to 2.4) using the R617FS 7-channel receiver. The left aileron is plugged into channel 1 and the right aileron is plugged into channel 6 and the ailerons work fine. I'm trying to change the setup to my Futaba 10CG radio and after binding it to the xmttr the right aileron works fine but the left aileron servo goes to full up deflection. I have endlessly studied the instruction books for both transmitters and there is no mention of how this setup is done other than just plugging the servos in to ch 1 & ch 6 or 7. Is there some kind of 'mix' step in there that I don't understand or what? I would very much appreciate any help.
Bill
Bill
RE: Radio Expert, Help!
Aileron diff...tun on the mix....I think it is 1 and 7...or you go to paramiters and change the channel.....I believe it is page 55 in the instruction book...
