RCGF 15CC
RE: RCGF 15CC
I would say to install it on the front of your plane ...Kidding aside..It looks like it comes with stand offs so it will just be a matter of figuring where your firewall center is and working out from there...Gasers run okay inverted so if you want to run inverted it should be okay . Gas tank placement is not so critical with gassers , the tank can be a bit further away and a little bit lower than the carb because the carb has a built in pump....I am going by the gassers I have , I have not had experience with the RCGF 15 CC . If it has a Walbro carb it will be the same
