servo mAh how much
My Feedback: (14)
IN
RE: servo mAh how much
http://www.servocity.com/html/hs-311_standard.html
go to this page. about half way down detailed specs is current draw, both idle and stalled
You can't figure battery capacity (how much flight time between charges looking at amp draw of a servo) There are just too many variables...everything from the way you fly, how the plane is trimmed to weather. The best thing to do is fly and check voltages with a loaded voltmeter, charge keeping an eye on how much you put in...do this for 3 or 4 trips to the field...now you have an idea what you can do.
