Carb (throttle) Horn
I have a old Thunder engine .61 that has a OS carb on it that is missing a control arm.I can find newcarbs but noarms. Canone converta control surface arm to go on the carb. This one is held in place with ascrew. Seems like you could drill aarm and put it on.Whatwouldyou suggest? I could just get a new carb but that 50.00 gphil
RE: Carb (throttle) Horn
Can you upload a picture of the carb?
Since you bought the OS carb, do you know the part number for the carb? Tower will list the carb and it's parts.
Carb came on engine and old style I assume. No back angle on needle. No # jus says "made in japan" I was thinking maybe a servo arm???
My Feedback: (14)
NY
My vote is for the servo arm I have seen it done many times and have used it myself a few times as well.. Not much stress on a throttle arm, or atleast there shouldnt be haha.
Good luck
-Steve E
Good luck
-Steve E
