If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 7 of 7
Thread: prop driver
  1. #1
    Join Date
    Oct 2011
    Elberton, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    prop driver
    how do you get the prop driver installed on a nitro engine? Mine is a 60 size. Need heat on part or what is the easiest?
  2. #2
    scale only 4 me's Avatar
    Join Date
    Jan 2002
    Avon Lake, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: prop driver
    To put it back on?
    Slide it on as far as you can by hand, then put a prop on and tighten it up like you're mounting the prop,, that should push it on the rest of the way until it bottoms out.
    Good luck
    You're so smart,, you figured out how to read this!! Or maybe ya just got lucky??
  3. #3
    Join Date
    Oct 2011
    Elberton, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: prop driver
    Keep it simple and that is it. Thanks for the info , I will try that. Thing is super tight , can just barely get it on the shaft. Came off fairly hard too. Rest of the overhaul went sweet. I will get back. gphil
  4. #4
    Join Date
    Apr 2003
    Hemderson, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: prop driver
    Heat will make it go on easier if you have a problem with it.
    Drinking and driving are illegal, why do bars have parking lots
    Daisy Air Guns, keeping kids off your lawn for 100 years
  5. #5
    Join Date
    Oct 2011
    Elberton, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: prop driver
    Tried heat but still was unable to even start it good in order to keep alighned. Came off there so should go back . Will see. gphil
  6. #6
    Join Date
    Jan 2002
    Avon Lake, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: prop driver
    Makes me wonder if it was damaged coming off, How did you remove it?
  7. #7
    Join Date
    Oct 2011
    Elberton, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: prop driver
    Ok fellas, the ole prop , nut ,washer and a little slow work got it back on. Thanks a lot for that idea,it worked great. So now I have a good .61 engine ready for a plane. No need for more input ,this place is the greatest. gphil
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
