Carb (throttle) Horn
Reply
Old 11-13-2012, 08:20 AM
gphil
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Carb (throttle) Horn
I have a old Thunder engine .61 that has a OS carb on it that is missing a control arm.I can find newcarbs but noarms. Canone converta control surface arm to go on the carb. This one is held in place with ascrew. Seems like you could drill aarm and put it on.Whatwouldyou suggest? I could just get a new carb but that 50.00 gphil
gphil is offline
Old 11-13-2012, 08:54 AM
da Rock
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Carb (throttle) Horn
The carbs that are in production have those arms available for a couple of dollars. Tower Hobbies
da Rock is offline
Old 11-13-2012, 08:57 AM
da Rock
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Can you upload a picture of the carb?
Since you bought the OS carb, do you know the part number for the carb? Tower will list the carb and it's parts.
da Rock is offline
Old 11-13-2012, 09:06 AM
gphil
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Carb came on engine and old style I assume.   No back angle on needle.   No #  jus says "made in japan"  I was thinking maybe a servo arm???
gphil is offline
Old 11-13-2012, 09:59 AM
R8893
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can use any arm that you can modify to fit. Been there, done that.
Chuck
R8893 is online now
Old 11-13-2012, 10:41 AM
Gray Beard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If the screw is in the center then most any arm will work. I use a lot of the arms that you find on the LA series of engines. I even use them on YS engines. My LHS usually has them in stock, they are about 2 bucks.
Gray Beard is offline
Old 11-13-2012, 02:28 PM
Bozarth
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have used a nylon futaba servo arm on an OS 1.40RX for years. Works perfect.
Kurt
Bozarth is offline
Old 11-13-2012, 09:36 PM
JohnBuckner
JohnBuckner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Have used so many servo arms on that type of carb you tend to loose count or is it perhaps because every time one is broken its usually because I just crashed
John
JohnBuckner is online now
Old 11-14-2012, 06:37 PM
AdamsBro
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My vote is for the servo arm I have seen it done many times and have used it myself a few times as well.. Not much stress on a throttle arm, or atleast there shouldnt be haha.
Good luck
-Steve E
AdamsBro is offline
Reply
Display Modes
