If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 6 of 6
  1. #1
    Join Date
    Mar 2007
    wilmington, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ca hinge strenthening
    I just purchased a Sig Kadet Sr. the control surfaces are already CA hinged,,do you think I should add a couple of drops of thin to make sure they are secure enough? Or will that not work,seeing how they are already hinged,,,,every thing is tight,,they wont pull out . I just worry they skimped on the glue ,,,you know how some of these factories short-chang us sometimes. Any way to reinforce the to make sure they are secure? Or should I worry at all.
    thxTAZZZZ[&o]
  2. #2
    JohnBuckner's Avatar
    Join Date
    Dec 2001
    Kingman, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: ca hinge strenthening
    Never try to redrop thin CA on Ca type hinges Once they have been dropped. You cannot redo them because the capillary action of the fibrous material is now compromised.
    Just gently pull along the trailing edges of the surface near where each hinges is and if there is no give then everything is fine go enjoy your airplane.
    There is even some thought that if you drop more CA at a later date that this could actually accerlerate a hinges failure (cracking or tearing at the hinge line itself).
    John
    \"Keep your controllines tight\"
  3. #3
    Join Date
    Mar 2007
    wilmington, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    OOOOhh WEEEEE,,,thanks ,,I guess Ill just put that thought in the hangar-Thank you sir.
  4. #4
    Join Date
    Aug 2010
    Sandwich, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    You can toothpick them, dill the trailing and leading edge glue in a toothpick sand flat.
    If you purchased it from SIG you should have a quality plane they are a great company. With that said I never use CA hinges I hate them I use pin hinges.
  5. #5
    Join Date
    Mar 2007
    wilmington, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yea,,so do I,, this is the first time Ive had a Sig pre-hinge anything,,,,,,,they staed that they changed manufacturers cause they had some sort of issues with the previous makers,,I definetly trust Sig ,,,theire good people.
    Thanks for the comeback
  6. #6
    KitBuilder's Avatar
    Join Date
    Feb 2007
    Palm Harbor, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    What I do to be sure on my builds (not arfs) is near the end poke a pin hole though the wood through the hinge and out the other side. With the skinny syringe type tip I drop in top of bottom... let it harden and lightly sand. This way CA has gotten to the far end as well.
    Mike -
    I was born a pilot... 100 years to late.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
