Cargo Trailer Ceiling Material
My Feedback: (10)
I'm renovating my Cargo Trailer to a decent Plane Hauler, the Ceiling/Roof is slightly curved and I want to insulate it with some styro which will not be a problem, the trick is what do I use to cover the ceiling afterwards, the ceiling has metal ribs that I can easily screw the covering onto, I'm thinking some thin gauge aluminum or galvanized tin from a tin working shop that makes ducts, etc; I figure it can bend to match the curve, light weight, can be secured to the ribs with self tapping sheet metal screws, etc; any suggestions, or am I on the right track?
Thanks.
Thanks.
RE: Cargo Trailer Ceiling Material
Would thin insulating panels be another option? Flexible and would supplement the styro insulation. It alsomight mitigate "hanger rash".
My Feedback: (109)
I used 3/4 inch foam board on my roof and then lined from the inside plastic panels from Lowes-they are white in color made of plastic in 4X8 sheets-same material as you would use in a not so fancy shower stall-cuts easily and screws with self tappers into the roof ribs-they have a 1 inch divider strip to join two panels at seam.
My Feedback: (10)
ORIGINAL: PLANE JIM
