How to Balance?
Reply
Old 11-16-2012, 12:34 PM
csandt051196
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default How to Balance?
Is it best to balance a plane right side up or upside down? Why?
Scott
csandt051196 is offline
Old 11-16-2012, 02:10 PM
BarracudaHockey
Community Moderators
BarracudaHockey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: How to Balance?
High wing = right side up
Mid wing = either way
Low wing = you guessed it, upside down
BarracudaHockey is offline
Old 11-16-2012, 05:28 PM
tailskid
tailskid's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
+1
tailskid is offline
Old 11-16-2012, 05:49 PM
jetmech05
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Why you asked because you want the weight down....it makes it easier... take a high wing...right side up all the weight is below the balance point upside down and now the weight is above the balance point and it will be impossible
jetmech05 is offline
Old 11-16-2012, 05:50 PM
JohnBuckner
JohnBuckner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
BaracudaHockeys list is right on and the reason is that to be able to find that balance point there must be sufficient weight below the
point of contact (balance pins) that the model can be stabile otherwise you can just keep readjusting and never find the real point.
Some airplanes ya just gotta experiment to find that stabile point. Look at it this way picture what would happen if you tried to balance a high wing airplane upside down, you would just not be able to find the balance point.
John
JohnBuckner is offline
Old 11-17-2012, 06:19 AM
jaka
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi!
I just hold the plane as it is. Two fingers under the wing and top of plane pointing up.
Come on guys this isn't Rocket Science!
ID:	1821182   Click image for larger version
ID:	1821183   Click image for larger version
ID:	1821184   Click image for larger version
jaka is offline
Old 11-17-2012, 06:25 AM
smithcreek
smithcreek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: jaka
No, you're right, it's physics 101. Holding a low wing plane right side up is not, by a long shot, the best method.
smithcreek is offline
Old 11-17-2012, 07:47 AM
jaka
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi!
But It's enough! Then I fly test my planes several times and move around the servos and battery untill I obtain a perfect C of G!
jaka is offline
Old 11-18-2012, 05:09 PM
Lnewqban
Lnewqban's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: csandt051196
Scott,
This great article will respond your question much better than I would do:
http://www.rcuniverse.com/magazine/a...article_id=601
Lnewqban is offline
Old 11-19-2012, 11:55 PM
evabuick
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
got it
evabuick is offline
Old 11-21-2012, 08:33 AM
skeeter_ca
skeeter_ca's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Lnewqban
Scott,
I think this article is a very simple way to explain it but really does not give a proper answer as to why it is easier to balance it upside down.
Place a low wing plane on a balance stand/finger tips right side up and say it is nose heavy. As the nose starts to dip down because of the nose heavy condition the large mass of the planes fuselage above the balancing point begins to move forward making it even more nose heavy. As the plane tilts forward even more the nose heavy condition gets worse and worse until the plane hit a stop or falls of the stand.
If the same plane is place upside down on the balance stand it reacts differently. As the nose drops forward the mass of the fuselage then moves backward like a pendulum. This offsets the nose heavy condition and if within certain limits will equal itself out and not fall of the stand.
Hope this is helpful.
skeeter
skeeter_ca is offline
Reply
Display Modes
