If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 4 of 4
Thread: Testers
  1. #1
    Join Date
    Oct 2011
    Elberton, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Testers
    Knowing all offered are probably good, I would like to know a allaround good battery tester. Talking about a field tester that will provide a load maybe to check internal battery on the plane and the transmitter. Now I know the radio has a meter on it but thinking maybe battery is going down a little fast. Anyway a nose pointed in the correct direction would work. I have a volt ohm meter but it does not apply a load. Thanks and once more will be watching. gphil
  2. #2
    Join Date
    Apr 2003
    Hemderson, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Testers
    Go onto Horizon Hobbies web site and look at there items, I have been very happy with all there equipment. I use the high end tach, TNC but I have tested it against several of the Volt Meter/Tach that Horizon sells and so far I haven't found a bad tach in the bunch. May as well get a two in one meter, both volt and tach. It will be with you for a lot of years.
    Drinking and driving are illegal, why do bars have parking lots
    Daisy Air Guns, keeping kids off your lawn for 100 years
  3. #3
    Join Date
    Jul 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Testers
    an expanded scale volt meter or Hangar 9 makes a volt meter with selectable load .5, 1 and 2 amp
  4. #4
    Join Date
    Jan 2004
    Repentigny, QC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Testers
    Put a 33 ohm 2 watt resistor in paralle with your meter
    can,t pos pic? how to
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
