repairing GP giant super sportster main gear
I repaired the main gear,,but I guess it wasnt strong enough,,she folded. Any ideas on repairing and strengthening the mains,,If not how do I remove the tail feathers (glued with 30 min epoxy) to install in a new fuse? This just happened in my back yard,,,,,,better there than at the field eh? HELP!!!!
Thank a million -TAZZZZ[&o]
My Feedback: (-1)
RE: repairing GP giant super sportster main gear
Photos!! It is usually just a mater of installing a new LG block. To remove items that are epoxied in you just use your heat gun and melt or soften the epoxy to remove the parts. I have run into some ARFs that where I would have used epoxy they had used some unknown glue that wouldn't soften. When installing a new LG b lock you will also need some angle stock to reinforce the block with.
As I recall the main gear in that plane was in the wing? Not the fuse? Been a while but I recall it was pretty flimsy.
Yeah,, thats my problem,,I did mount the aluminum gear to the fuse,,,Im just trying to figure out how Im going to reinforce to where its strong enough. TAZZZZ
