If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 6 of 6
  1. #1
    Join Date
    Apr 2011
    durham, UNITED KINGDOM
    servo power supply help.
    Hi, im putting together a sbach300 with a dle 30. Im new to petrol power and the largest model i have is 60 size glow so this is a bit bigger than im used to.Im putting in 5 savox sc0252mgservos and was wondering will i need a separate power supply for the servos or will they be ok to go through the rx. Any advice on what else i should do would be great. Thanks.
  2. #2
    DavidAgar's Avatar
    Join Date
    Dec 2001
    Battle Ground, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: servo power supply help.
    Your reciever battery will power your servo's. You need a seperate battery for your engine ignition. Good Luck, Dave
    If the screw ain\'t loose then things ain\'t normal.
    Dave Agar
    AMA#97144
  3. #3
    Join Date
    Feb 2002
    Leander, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I use three batteries in my bigger gassers. (rec only, servos, ignition) I fly spektrum so keeping the receiver on its own battery is insurance against voltage sag due to high current servos. I use a split power bus from servo city, http://www.servocity.com/html/servo_power_boards.html . Thats the cheap version. There are others from smart fly with built in regulators. I dont fly 3D so weight is not much of an issue for me. But I imagine it is in the aerobatic world.
    Edwin
  4. #4
    Join Date
    Dec 2008
    pine bluffs, WY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    EDWIN +1 and all 3 systems are on 6V 2700mah batts.George
    keep your powder dry and pray the creeks dont rise.
  5. #5
    Join Date
    Jul 2005
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Power through the receiver will be ok...must people that fly gassers will run 2 batteries for system through a batt share of some sort or with an additional battery through the receiver (not the best choice) and the 3rd battery for iginition. Also get an optic kill switch...will shut down the engine in case of a total loss of power to the receiver...and give you an additional way to kill the engine from the transmitter
  6. #6
    Community Moderators BarracudaHockey's Avatar
    Join Date
    Jul 2003
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Get an A123 with two leads, run one to the reciever, one to the ignition with a voltage drop down diode, heavy duty switches on both the ignition and reciever line.
    Those servos are fine running off the power bus on the reciever and you dont need a separate battery on a little plane like that.
    WrongwayRC.com has everything you need.
    +1 on the optical kill!
    Andy - RCU Community Moderator
    AMA 77227 Leader Member- Contest Director
    www.JaxRC.com
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
